Old 01-05-2010, 12:39 PM
myslon myslon is offline
after cleaning jets , spark plug are foulled with carpon
hello can anybody help me with this
after i cleanead the carburator jets , all sparks plugs become foulled with carbon deposits , and an engine vibration even i am pushing the acceleration pedal down far pls tell me what shall i do ,
i got in my mind the idea of decreasing the jets size or changing the cleaned jets . is this a good solution ,
pls reply asap , because i stopped using my car after this happened today
best regards
myslon
Old 01-05-2010, 02:34 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: after cleaning jets , spark plug are foulled with carpon
What did you clean the jets with?. Usually carbon fouling is a result of a car running rich (too much gas). If the jets were inadvertently enlarged then you'd be introducing too much gas into the cylinders.
Vehicle brand/model and mileage might help...
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-05-2010, 11:15 PM
i know it is now richy , you added nothing to my experiance. i want to know what really happened when i cleaned te jets and emulsion tube with the carb cleaner
Old 01-05-2010, 11:18 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
He's trying to help, if you really want that help you need to answer his questions.
Old 01-06-2010, 08:11 AM
sorry for my arrogance, it is lada niva
Old 01-06-2010, 11:07 AM
jdmccright's Avatar
The RustBuster
Not a common vehicle in this forum to be honest, but I did find a very nice diagram of the Lada Niva's carburetor, located here (Photos 9 and 10):
http://www.scribd.com/doc/21560551/L...stration-Album
There could be a few things going on from my limited carb experience:
1) The idle fuel adjustment screw needs to be reset.
2) The floats/needle valve are not metering fuel correctly and/or overflowing the bowl.
3) There may be a problem with the choke not disengaging after warm-up.
Does it start easily? Can you describe how it runs...if it runs? Does it run better after it has warmed up? As I understand, it runs poorly at all throttle positions with little power, but is there a position where it runs better or normal? Half way? Full throttle? Was anything else changed or repaired on the vehicle at the same time?
Hopefully, someone with more carb experience will chime in, but we are trying to help. Frustration is common, but the speed of the Internet is not instant, so please be patient. Thanks!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 01-08-2010, 03:42 AM
thanks man
u did it , u fixed my car with this info and pics
i appreciated my
and sorry 4 my arrogance
