Old 03-20-2004, 04:39 AM
2gooses 2gooses is offline
engine surging
when i start my metro 3cyl. the engine rpms surge from 800 -3500 rpms, how do i figure out the problem? it also does while driving
Old 03-20-2004, 11:19 AM
geozukigti geozukigti is offline
Your TPS(Throttle postition sensor) is outta whack. A service manual will explain how to re-adjust the TPS. Also, i've noticed the IAC solenoid can cause this too. IAC=Idle Air Control valve. A service manual will tell you where this is. My GT was doing that, and I just unplugged the wires from it, and my idle instantly stopped surging.
Old 03-27-2004, 03:01 PM
geojim geojim is offline
My '93 Geo also had an engine surge before it went back down to normal idle. I suspected a vacuum leak and began searching all the vacuum lines looking for breaks or leaks. Found one and fixed it - surging went away.
Old 04-09-2004, 12:34 AM
kingmt kingmt is offline
Re: engine surging
Check for vacum leaks first. I don't know if you have an IAC but if you do don't unplug it. Clean or replace it. If all alse falls check timeing & comprestion.
199 Maxima engine surge kmckinno Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 09-25-2005 01:20 PM
1993 JGCL Engine Surges, Check engine light Jeep93GCL Grand Cherokee | Grand Cherokee SRT8 5 06-04-2005 09:38 PM
engine surging jsoroka Bonneville 12 07-27-2004 06:03 PM
Engine Surge to go with check engine light SootheMyPain Passat 2 05-06-2004 12:41 PM
Mean engine surging no codes..Need Help bbrianr '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-11-2003 06:22 PM
