Old 03-20-2004, 03:00 AM
VTcommo VTcommo is offline
Banned
Send a message via AIM to VTcommo
puting another amp in.
HI im buying another amp, i already have a 4 channel amp. Do i have to run the that wire from the battery to the amp, or can i just connect a wire from the amp i already have into the new one? I want to add extra power to my 12" sub!
thanks
Old 03-20-2004, 08:38 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: puting another amp in.
You have a 4 channel powering a 12...
Anyhow... You will want to get a thing called a distrobution block.
www.cloudcity.deviantart.com
Old 03-20-2004, 06:18 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you may need a bigger wire from the battery
Old 03-20-2004, 08:26 PM
Banned
yer 2 channels from the four channel amp r powering the 6x9s, and the other 2 channels r bridged to the suby. if i get a bigger wire from the battery can i connect the second amp to the one already installed?
what is a distribution block.
Thanks
Old 03-21-2004, 12:08 AM
benny27 benny27 is offline
Re: Re: puting another amp in.
Thanks
this is a distribution block
http://store.autotoys.com/cgi-bin/wf...UTIONBLOCKGOLD
you will run the wire from the battery to the distribution block and then run 2 wires from the distribution block to the amps 1 wire for each amp.
your locale shop should have them and be Abel to tell you just how to hock it up.
what size wires do you have now??
(power and ground)
Old 03-22-2004, 05:57 AM
Banned
IM not 100% sure, but i think 8 guage, so may not be enough ill check and get back to you.
Old 03-22-2004, 12:13 PM
If it is 8 guage then just get a 4 guage to go from the battery to the distribution block and use the 8 guage from the distribution block to the amps....put the distribution block as close to the amps as you can too....
Old 03-22-2004, 06:17 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Wait, so you have a 4ch powering your sub now, and you want to add another amp to power it even more?
You can only have one amp powering a sub, you absolutely cannot hook 2 amps to a single sub to "give it more power" (other than attaching 2 identical amps to each coil on a DVC, but you're not doing that here so it doesn't matter).
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 03-24-2004, 05:07 AM
Banned
no the 4 channel amp is running 6 by 9s aswell! so ill get another to run the 6 by 9s sepeartae and use the 4 chanel to power the sub if possible.
Old 03-24-2004, 05:59 PM
Audio Guy
I think I would use the 4/ch amp for the other speakers and get a bigger amp for your subs. You might want to put speakers in the front as well
puting a stereo in a 2000 s type. RickwithaTbird S-Type 5 09-27-2005 07:33 PM
another amp question hotwheelsgt Car Audio 8 07-18-2004 02:04 PM
Adding another amp?? makaveli3004 Car Audio 2 06-29-2004 08:53 AM
