Old 03-18-2004, 10:47 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Dead Truck???
I have a 75 K20 with a new 350 motor in it. When ever you put the truck in any gear except neutral or park the rpm drops and the truck dies 5 seconds later. The truck has a perfect idle when in park or neutral. I would guess that the rpm drops to about 500. Any suggestions???
White 07 STI, Bone stock for now
Old 03-19-2004, 07:40 AM
Gooseneck Gooseneck is offline
Re: Dead Truck???
Check your timing, a out of time engine can idle fine in a no-load situation. also check for vacuum leaks.
Old 03-22-2004, 08:44 AM
timberdoodle timberdoodle is offline
Might have a fuel problem too, the rpms are supposed to drop a few hundred rpms when u put it into gear, but something is causing it to stall because it cant run with the engine turning that slowly.
Old 04-20-2004, 05:24 PM
toivo toivo is offline
Re: Dead Truck???
put a vacuum guage on it, it should run between 18 and 21 inches of vacuum at idle.
01 Kia Sportage 4x4 DEAD No start No power Needs jumpstart everytime HPYUNBDAY Sportage 2 07-27-2011 08:45 PM
01 Expedition - Battery Dead in 45 Minutes djtroz Expedition 6 02-04-2011 01:53 PM
Lost Key AND Dead Battery! db99 Town Car 7 06-09-2010 10:25 PM
2005 Avalanche "Service Stability" message, then dead truck 2005Avalanche Avalanche 2 07-19-2009 05:20 PM
