Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 03-18-2004, 09:59 PM
kchiruvolu kchiruvolu is offline
Ecu
Hi All,
I have a 1992 Mitsubishi Mirage which stopped suddenly on the road. I had a mechanic do
diagnostics on it and it was concluded that the ECU (Engine Computer) has gone bad. Can you
guys please tell me where I can find it in my car and how do I replace that. Do I need any special tools? Thanks in advance for your help.
KC
Old 03-20-2004, 05:32 PM
evoryda evoryda is offline
whats up man? the ecu on my mirage is on the pass side, on the side wall behind glove box. it helps a lot to take the GB off to get to it, there are harnesses to unplug and i think theres only nuts holdin it on. hope that helps
Old 11-27-2004, 06:44 PM
gdelcarmen gdelcarmen is offline
Mitsubishi Mirage
Hello,
I have a 94 Mirage that died due to ECU failure...I ve been told that these ECU aren't very reliable. Is it worth replacing it. Do they make a more reliable one that I can buy and how much.
Thanks for you help
Old 11-28-2004, 10:32 PM
miragenut miragenut is offline
Send a message via Yahoo to miragenut
I have a 93 Mitsu mirage and i found my ECU mounted under the middle console behind the shifter. The passenger side is the most likely but it doesnt have to be there.
Old 12-16-2004, 01:59 AM
mirageproject mirageproject is offline
Re: Ecu
you can always try to aquire a 97 mirage ECU. for some reason they are more coveted than the rest. not sure if it will work on a pre 96 though. check www.mirageforums.net to see if those guys are selling it or know.
ecu ecu ecu i see you MODIFIED_GSR Integra 7 05-04-2005 09:31 PM
converting ecu plugs to OBD-1 ???? p08 ecu install SIvic '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-21-2003 12:28 PM
88 ls ecu vs 89 ls ecu outofstep '71-'87 Civic | CRX 5 04-13-2002 01:41 PM
99 G20 ECU vs 98 Primera ECU bafo Engine 2 01-29-2002 01:29 PM
