Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 03-18-2004, 06:40 PM
White Xterra 00 White Xterra 00 is offline
horn question
my horn on my X seems to be softer then when i first boight it.... i htink there is something in it. Is there a way to clean the horn? Or could i just replace the horn with a new one? ANd if i can, how do u replace the old horn with a new one?
Thx!
I don't know
Old 03-19-2004, 02:04 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: horn question
Thx!
Yeah, they can clog up. One of the guys in our club was able to get 3 new horns under warranty. If you offroad, forget about the stock horn ever being usable. It's easy to replace if you want. Just buy a new one at an auto store, pull the old one and replace using the wires there. All you need is a phillips screwdriver and maybe a socket wrench, but I don't think you even need that. I just said screw it and bought an airhorn and relocated it in the engine compartment.
Xterra4x4.com and the Xterra Offroad Webring
Old 03-19-2004, 08:50 AM
hey, thank for the info.... my friend and i just put a new horn in last night and it sounds a lot better!
I don't know
Old 03-19-2004, 11:20 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: horn question
Aw c'mon Schlud, you gettin' soft? Saw you had replied and figured you beat me to pointing out the "IMPORTANT:..." post at the top of the How-to/Installation (SHARE your techniques with other owners) section
It ain't workin' apparently, ho-hum.
Old 04-17-2004, 07:25 AM
molloy molloy is offline
Re: horn question
Thx!
I have a similar problem with my 2000 Xterra's horn. My horn started to get weak sounding about a year ago. I removed the horn wire uner the hood and cleaned the connections. It sounded a little stonger after that, but now it is actually not working at all when I press on the steering wheel. It does, however, still make a pathetically weak sound when I use the remote key lock. I was told that it might be the button on the steering wheel and that they would have to depressurize the air bag to even look at it. They said it would probably cost over $100.00 to fix. I need to pass inspection in June and would appreciate any input as well. Hope yours works by simply cleaning it ... good luck.
BJ
Old 04-17-2004, 11:28 AM
XTerra Guy
Get another dealer. They're lying to you. Depressurize the airbag.
Go to an autoparts store and buy a new horn, then plug it in.
Old 04-17-2004, 02:23 PM
Re: horn question
The 2000 has 2 horns, the main one in front of the radiator, and an alarm-only one towards the rear of the passenger side of the engine bay.
Schlud, care to move this to the electrical section?
Old 04-18-2004, 08:02 AM
Toy Man Toy Man is offline
AF Premium User
I have tried Hella horns, Wolo horns and recently switched to the Griot air horns. All were fairly easy installs with the airhorns being the easiest. The Hella's were good but I like the air horns the best. The airhorns were also the cheapest.
Upgrade your horn fuse to 15 amp if you put the air horns in.
Griots Garage
Toy Man
Old 04-19-2004, 11:02 AM
Re: horn question
These? http://www.griotsgarage.com/catalog....2520&SKU=77839
Interesting...
Old 04-19-2004, 02:03 PM
AF Premium User
Yes those are the ones.
Loud and penetrating.
Easy mounting and do not take up much space.
Toy Man
Tachometer and horn questions iceman33 Stratus 1 09-29-2007 06:06 PM
air horn questions crazycat Suburban 2 05-08-2005 04:06 AM
01 Alero GLS locks and horn question ttwotees Alero 0 02-27-2005 08:10 PM
Air Horn Questions crazycat Silverado 4 10-14-2004 12:20 AM
Horn question crapmaster4000 Camaro Discussions 6 04-22-2004 10:12 PM
