Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-18-2004, 06:09 PM
izrtrueblue izrtrueblue is offline
Unhappy 93 ranger 2.3 5 spd fuel distrib system
I have a 93 ford ranger that I just replaced the fuel pump on, but there is no sound indicating the fuel pump has electrical current. Does any one know how to work through this problem?
Old 03-22-2004, 01:45 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 93 ranger 2.3 5 spd fuel distrib system
check the fuse, inertia switch, fuel pump relay and tfi module. also make sure the ground in good. the pump should energize for 2 seconds when the key is initially turned to run. usually the relay or wires to the relay are the culprits. i think you can use a jumper wire on the eec connector to energize the pump circuit but don't know offhand which terminal it is.
92 Crown Vic, Need 2 replace FUEL FILTER... CrownVicChick Crown Victoria 4 08-15-2010 09:35 AM
1999 Jetta GLS 2.0 AEG Fuel system problem Probe '97 - '03 3 04-20-2010 10:24 PM
83 Ranger 2.3 Interference Engine? kbkaiser Ranger | Courier 1 07-07-2005 07:04 PM
my 95 ranger 2.3 mjj1952 Engineering/ Technical 0 09-18-2004 03:20 PM
freeze plugs on 92 ranger 2.3 bbookland Ranger | Courier 0 02-02-2004 10:40 AM
