| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Transmission swap?
Just curious if anyone could help? Ive got a 91 Lude si with the b21a1....Does anyone know what or how hard it would be to modify the automatic transmission currently residing to a manual tranny. Such as pedals, cables, mounts etc. Any help would be much appreciated.
Re: Transmission swap?
Aside from the mounts probably being different on the tranny side, shouldn't be too hard, provided the chassis was drilled for it all from the factory and everything can bolt up.
hit me up i have the parts and info for your swap
you can't just convert an automatic transmission to standard... you have to put in a clutch, clutch pedal, and standard transmission, and also either swap out your ECU with one for a standard, or send it out to be flashed.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors). To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods. check me out on: http://www.cardomain.com/memberpage/515191 |
Re: Re: Transmission swap?
flashing is reprogramming... you know like the flash cards in a digital camera... our car ECU's use the same type chip... just a bit different...
