Old 03-18-2004, 01:17 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Question Need Transmission help
My tranny I got with my swap started making some noise about 5oo miles after I got it in, At first reverse started making some cracking noise when I backed up, Now first gear will start chattering if I let the clutch out too slow, like when driving slowly through my apartments. I had the car up on stands the other day and when I started it the passenger side wheel started to spin very slowly even though it was in neutral. I'm thinking it's the clutch and/or the throw-out bearing or the case bearing...does this sound right? If I replace those would I be alright or should I start lookin for another tranny?
Old 03-18-2004, 06:26 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
my dads bike was having some clutch problems. In neutral on its stand the back wheel would spin slowly but it doesnt do it as much now because my dad flushed the fluid and cleaned everything. Hes selling the bike acctually. He bought a gibson sg special and when he sells it hes gettin a marshall half stack. Sounds like you have the same problem but way worse.
1991 Honda Civic DX Sedan
Old 03-21-2004, 07:25 PM
dagoEF's Avatar
Re: Need Transmission help
Any other ideas anyone?
Old 03-21-2004, 08:46 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
your wheel will spin when its in neutral. It just does that, it doesnt mean your tranny is bad or anything. The chattering, well... sounds like you have clutch chatter. Did you put a new clutch in when you did the swap? Did you get your flywheel resurfaced? Those are things you should really do. As for the noise in reverse, i dont really know. I dont know too much about trannys yet. But make sure your fluid is up to level, then let us know whats up.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
transmission not engaging guys i need your help cyberfastpush Trans Sport 1 03-12-2010 04:58 PM
Need transmission help !!! Taasman Explorer | Explorer Sport Trac 2 03-06-2004 06:28 AM
i need transmission help hbtwarrior Camaro Discussions 0 02-04-2004 11:49 PM
Need Transmission help highvoltage0823 Engineering/ Technical 2 07-16-2003 01:48 AM
Need Transmission Help Dahmin8 Accord/TSX/Accord Hybrid 1 07-15-2002 05:53 AM
