Old 03-18-2004, 01:47 PM
pavrgv pavrgv is offline
Send a message via Yahoo to pavrgv
92 / 1500 gear problem
ok, here it is....
I get a whirring noise while under accelration and decelerating. No sound while coasting. I have replaced the gears (ring and pinion) I have fiddled with it so much i can get in and out of the pinion in less then 3 hours.... i dont have an arbor guage, just using a feeler guage....I am starting to think it may be the transfer case.
for you pros...the truck is a 1992 with a 350, th700r4, 4x4. it has about 108000 miles on it. replaced the tranny about 10,000 miles ago. I put the stock 3.42 gears in the rear and the rear end is the GM 8.5. 10 bolt. The gears installed are the factory gm...Not richmond or other off brand.
yes i have through a couple of crush sleeves!!!!!and if I have to tear into again, Ill have to replace another.....
thanks
anyhelp would be great......
Ron
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 10:58 PM
1995 Dodge 1500 rear end problems alley30577 Ram Pickup | Ram SRT10 2 02-19-2010 10:37 PM
2000 chevy 1500 gears grinding but not tranny evoeric Silverado 25 01-06-2010 07:55 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 05:24 PM
e-gear problem in 1st gear when the engine is cold blaise Gallardo 52 08-21-2004 08:54 PM
