Go Back   Automotive Forums Car Chat > Oldsmobile > General Discussion
Old 03-18-2004, 10:47 AM
swmissouri swmissouri is offline
1994 lss ignition problem
have a 1994 lss with 3.8 with no spark. started out that numbers one and three cylinders would not spark under normal acceleration but would under heavy acceleration until speed was leveled off then they would quit firing again. had shop look at it and they replaced ignition module but it did not fix problem. car is now in my garage and i am trying to check it out. removed front crank pully and checked sensor and back side of pully and found nothing broken. i am going to replace crank sensor if it is not real expensive (144000 miles). need to know what specs are for cam sensor to check it. turned engine over and checked cam button and it is ok. the shop i had it in also tried a new computer and that did not help. also does anyone know where i can find a wiring diagram for ignition system for this model. thanks in advance.
1994 Cutlass Ciera ignition problem Velvet_Ravyn Cutlass Series 4 10-02-2014 08:12 PM
Ignition problem? Jeffstevehow Explorer | Explorer Sport Trac 1 06-22-2010 12:15 PM
1994 Corsica Won't Start Ragarianok Corsica 0 05-09-2010 04:53 PM
1994 Taurus Ignition Problems karaz Taurus | Taurus Wagon 1 12-06-2005 01:26 PM
1994 lss ignition problems swmissouri Eighty Eight 2 03-22-2004 01:57 PM
