Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 03-18-2004, 10:29 AM
CHASESMITH CHASESMITH is offline
Radio Display Won't Light Up
Hi, I'm New To The Forum, I Have A 96 Se With 271,000 Miles On It, No That Wasn't A Type O. It Is In Perfect Condition (knock On Wood), But The Display For The Time/radio Station Doesn't Light Up. I Was Just Wondering If It Was A Simple Fix Or I Have To Replace The Radio, Because I Really Don't Want To Lose The Steering Wheel Controls.
Old 03-18-2004, 11:41 AM
MethodMan420's Avatar
MethodMan420 MethodMan420 is offline
Re: Radio Display Won't Light Up
This is a simple fix with a little know how and a few globs of solder. The most likely cause of your backlight going out is cold solder. Once the radio is removed slide a flat blade screwdriver under the 4 plastic retaining clips (2 on each side) on the side of the radio, once these are unlatched firmly pull on face plate. The bulb should be located on the top part of the circuit board. Use your screwdriver to turn bulb counter clockwise, put 2 "globs" of solder on the pads where the bulb contacts, if you put too much on the bulb won't go back in. Put the bulb back in, gently work face plate back on (being sure not to bend the metal contacts on the bottom of the face) once in firmly push until it clicks into place, if it doesn't go in easily, be sure contacts are seated properly. Before putting your dash back together verify that the bulb is working by plugging unit in and turning your key to the acc position. If the backlight is still out order (link #1) your new bulb and install it as described.
http://www.corvetteradios.com/Page7.html
I just found this link that pictures what I had just described http://www.corvetteradios.com/home/bu6.jpg
Good luck
___________
/|____________|\
[|___\==A==/___|]
||||________||||
Old 03-18-2004, 02:50 PM
Keller0512 Keller0512 is offline
Send a message via AIM to Keller0512 Send a message via Yahoo to Keller0512
Hey, I have that same problem with my 1996 Bonneville. With mine, if you touch any of the controls on the radio it'll shut off. You can only use the controls on the steering wheel to work the radio. I was wondering if you have that same problem with yours.
Also could you post instructions on how to remove the radio from the dash. Thanks for the help,
-Rich
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
Monsoon Radio Display Light akimmel Camaro Discussions 5 02-25-2008 12:24 AM
Radio display going out; CD won't work tinystitches Explorer | Explorer Sport Trac 44 09-15-2007 05:55 PM
Radio Display/Clock Light GMRC Montana/Montana SV6 3 03-21-2005 09:21 PM
when I cut on my lights my radio display goes off,and my blinkers etc are messed up.. frank_a Grand AM 1 09-20-2004 03:26 PM
