Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-07-2002, 02:23 AM
ACCSlvCivic ACCSlvCivic is offline
Send a message via ICQ to ACCSlvCivic Send a message via AIM to ACCSlvCivic Send a message via Yahoo to ACCSlvCivic
Minimize drifting
Today a took a turn going quite a bit quicker than i should have -grin- anyways i had a nice drift going on, no big deal. Scared the crap out of my friend riding with me though. Anyways, what can i do to prevent drifting when taking sharp turns quickly? I've got my car dropped roughtly 2" and i have upper tie bars and of cousre rims w/wider tires. Is there anything else i can do to keep from breaking loose or at this point am i limited to just the ablity of the tires to stick to the road? would a lower rear tie bar or thicker antiswap bars help that? i'd think i'd be just as likely to drift, but i just want to check!
thanks
1998 Yellow Civic Coupe 5spd EX
Wings West Avenger Kit
Z3 Fenders
c/f hood
Custom Spa Yellow (s2000) paint job
Blacked out taillights
triple beam projector headlights
16" Enkei TBS11s w/Paradas all wrapped around them
Aluminum Front and Rear upper tie bars
Custom CAI, JG 4-2-1 Header, Custom Racing Madalion catback exhaust (2.25") with testpipe
short shifter and Neuspeed shifter bushings
Pioneer DEH-P7300 CD player w/6CD changer
orion 800.4 xtreme amp, 2x 12" eclipse subs, and some 6.5" Focal componts from the polyglass line (6v1)
Next up:
GSR Swap and hopefully some sponsorship?
Old 01-07-2002, 12:07 PM
texan's Avatar
texan texan is offline
Writer Mod
If by heat drop you mean that someone toook a blowtorch to the springs, REPLACE THEM IMMEDIATELY. Beyond that, drifting a fwd car is all about improper driving style (or proper driving style, depending whether or not you meant to do it), go down to your loco SCCA chapter and sign up for the next autocross session. Within 6 months you should notice a big difference in your driving ability, especially if you take instruction well.
'03 Corvette Z06
'99 Prelude SH
Old 01-07-2002, 10:30 PM
praxis praxis is offline
I agree with Texan...SCCA is a great organization to be involved with. The 'veterans' are always there to help you. I started racing in the summer of '00 and have noticed a huge change in driving skills and (good) habits. I am finally getting used to heel/toe driving.
PraxisPerformanceAutoworks LLC High performance autoparts & accessories.
________________________
sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers
_____________________________
PraxisForums...informative information
PraxisRacing is sponsoring. click for more info.
see PureHonda in its original colors-->
Old 01-08-2002, 01:23 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Sorry but by definition you can not DRIFT a FWD car. Because its FWD the wheels will PULL the car back into a straight line... where as a DRIFT with a RWD car you can do whatever, keep going sideways, flip the wheel around while still drifting and drift the other direction etc. What you did was basically a "power slide" and is bad driving, have fun replacing your tires
AF's Official Asshole
RIP AUNIE
Old 01-08-2002, 04:11 PM
texan's Avatar
Writer Mod
The front tires only pull the car back into a straight line if they have traction, and even if they do you can still throttle steer a powerful fwd car (though not to the same extent as in a powerful rwd car). A drift is a huge tail-out slide going around a corner by which you controllably clip the apex and smoothly exit the corner under power (yet are countersteering the whole way), any powerful car can do that on any surface given the right suspension setup and driving technique. Of course that's just my opinion, and I do agree to some extent that drifting a fwd car is always a different driving technique than drifting a rwd car.
'03 Corvette Z06
'99 Prelude SH
Old 01-11-2002, 01:12 AM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
Come on dude I drift my car all the time, I deflate my rear tires to simulate RWD conditions
No I agree, He is talking about a slide, not to be confused with drifting, which for the most part is driver induced. Like you said, about how drivers do it and why, I think the term "drift" is being thrown around a lot, as a way to take corners
It is well know this is not the fastest way around the track, looks fun though.
So to the topic, if you are concerned with sliding, then exactly how are your slides? Are you understeering (breaking the front loose) or oversteering (breaking the rear loose) or are you just sliding evenly, neutral, sideways?
Much of how your car slides is associated with how you enter, follow and exit turns. Your slide may not be a vehicular issue, but rather a driver issue. So it is hard to recomend, a solution. I know you want a generic answer.
Generally I would say to reduce sliding, is to increase grip. That starts with stickier tires, tire pressures,and alignement angles. That is the easiest way to start, but this is a very generic answer.
And I and many people here could fill up pages worth of how to tune your suspension.
M.Sanew - AutomotiveArticles.com
Old 11-17-2003, 12:36 AM
lexicon_1 lexicon_1 is offline
Send a message via AIM to lexicon_1
DRIFTING COMP
its possible to drift a fwd car, I've done it myself. Check Mark Rosso and some of his japanese/euro counters and you'll find that drifting is possible in little hondas. E-BRAKE! yell that at the top of your lungs and you will have found the key!
Old 11-17-2003, 12:59 AM
SiGNAL748's Avatar
SiGNAL748 SiGNAL748 is offline
Send a message via AIM to SiGNAL748 Send a message via MSN to SiGNAL748
i usually call fwd "drifting" ass dragging... but respect to the guys who can pull it off cleanly.
anyway, i think the term "Drift" should stay in the rwd world.
Old 11-17-2003, 03:07 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
FF drifting is I think a personal prospective topic. There is no real true answer to it since "drifting" originated in the RWD crowd. To me E-brake induced drifting is "ass dragging" whereas a total 100% weight transfer induced "drift" is more like a true drift for an FF configuration car. I have weight transfer drifted my EJ6 coupe before, though it was by no means intentional. The way my car is set up now, it has a strong tendancy to push at the rear and not plow much if any at the front. Depending on how I want to attack a curve, I can plow it or oversteer it at the flick of thw wheel and/or tap of the brake pedal and controlling the throttle. I never use E-brake when I take turns/curves, so I can tell you first hand it's not required to get a FWD drive car to drift or rear end slide. Like mentioned above, tire pressure and suspension setup has MUCH to do with how well if at all your car can oversteer if FWD. With my setup I have true full coilover shocks with 559f/336r springs on them, a 22mm rear swaybar, rear lower tie, front upper bar and "15 wheels with 205/50 15 Yoko ES100s. With the suspension set at the optimal stiffest setting (as stiff as possible at the rear, and 4 settings softer up front) and about a 4-5psi differance in tire pressure with the greater at the rears, I can get my car to push out of almost any corner, and not plow really any in hairpin type turn situations.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Drift to Park - Street Style Racing game Cromuland Other Games 1 05-23-2014 08:46 PM
Merc SLS, Veyron and Ferraris drifting at carshow thhedk Car Videos 1 04-19-2010 06:37 AM
minime ? brettex '88 - '91 Civic | CRX | Wagon | Shuttlee 5 03-17-2004 07:30 AM
How to minimize torque steer and speed up take offs intelligence27 Off-Topic 0 11-19-2003 12:35 PM
Minimal Respect... -The Stig- Street Racing 16 11-07-2002 01:55 PM
