Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-17-2004, 06:05 PM
Purf02 Purf02 is offline
Angry 98 Jetta: Dome light
My dome light remains on if in I put it into the door open mode. (ie. I can't leave it on because stays on permantely even after closing door but so now i have no light in my car unless I manually turn it on...) Also, my alarm goes off if I lock my car, possibily door sensor related? Any suggestions to check/repair problem?
Old 03-18-2004, 03:12 PM
boschmann boschmann is offline
Re: 98 Jetta: Dome light
Yes it sounds like a door contact switch or wiring problem. You should also check where the harness goes from the door to the body near the hinges. The wire you're interested in is the brown w/white trace wire. It goes to ground when a switch is activated (door opened). Hopefully you will first find a place where a wire has rubbed & shorted to ground. Note that all four wires are connected to each other before going to the dome light, so if you check with a test light, starting at one door, you need to disconnect the wire/switch from the rest of the system to check each switch.
VERY Hot Dome Light hot dome light man Grand Prix 5 10-02-2010 11:11 AM
2002 Express dome light issue jtram2 Express | G Van 2 07-23-2010 07:57 AM
TIP: Fix those doorjam switches // no dome light... Intuit Escort 3 11-21-2009 10:27 PM
Headlights & Dome Lights GirlLovesCamo Venture 1 11-01-2009 12:57 PM
Map lights stay on... cs2009 Bravada 2 07-01-2009 12:28 AM
