Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 03-17-2004, 12:17 PM
afripino afripino is offline
Lightbulb 97 Neon Got problems....need help!!!
Two problems....
1) On start-up, there's a squeaking noise, but it goes away on idle and when I rev. The squeaking noise does however come back occasionally (seems to be randomly) during defrost or a/c. I'm thinking somethings up w/ a belt, but how would I go about fixing that myself? Which belt would it be?
2) As soon as I hit 70 mph (exactly) the steering wheel shakes alot!!! I'm thinking alignment, balance, rotation....but is there anything else it could be?
Somebody help me out.....
Old 03-20-2004, 04:38 PM
NeonStyl NeonStyl is offline
Send a message via AIM to NeonStyl
Re: 97 Neon Got problems....need help!!!
1) Yep, most likely a belt... check HERE for a Accessory Belt How-To. Replace and/or adjust tightness of those as needed.
2) Ahh, the infamous 70-mph steering wheel shake! This happens alot to first-gen Neon's... it could be any of the things you listed above, however you can search for 70 mph shake on www.neons.org's forums for alot more info on this.
L8R,
~NeonStyl
- www.neonspeed.com -
Old 03-20-2004, 08:32 PM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
For the shaking, inner tie-rods, alignment, and new tires,or bringing the back tires to the front will work. Putting the front tires in the back will smooth the swivel lines on them. Swivel lines are caused by the tire not rolling directly straight. And can cause a little shaking at faster speeds. And the rods take the abuse.
97 NEON DIES. Confused. Need help. NFarran 1st Gen 95-99 15 07-02-2005 09:18 AM
2002 neon problem NEED HELP AAR70CUDA340 General Discussion 1 04-13-2005 09:37 AM
Got a wired problem. need help!!!!! G35turbo 3000GT/Stealth 4 02-26-2005 11:56 AM
neon issues... I NEED HELP please deemanota Neon | Plymouth Neon 2 08-19-2004 01:22 AM
1996 Neon problems - need help james702 1st Gen 95-99 0 08-15-2004 08:52 AM
