Old 03-17-2004, 11:33 AM
aleekat aleekat is offline
Side Mirror Vibration
98 Blazer LT. Driver's side mirror vibrates when driving. Is the glass removable without removing the entire housing?.ie, the door panel.
Old 03-18-2004, 07:44 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Just remove the door panel and tighten the bolts holding the mirror on..
Old 03-19-2004, 09:37 AM
I'll try it, but it looks more like the glass is vibrating in the housing, not the housing itself. These are power mirrors.
Old 08-25-2005, 03:06 PM
chigger23 chigger23 is offline
Re: Side Mirror Vibration
I had same thing and it was gong when they replaces the Hinge Pins in my door, they had rusted, Look theere and I may help.
Old 08-25-2005, 04:04 PM
XPC2004's Avatar
XPC2004 XPC2004 is offline
Send a message via MSN to XPC2004 Send a message via Yahoo to XPC2004
I;ve had that problem, it still occurs, all I do is move the mirror a bit and it tightens it. It does losen again, just move it again.. voila... yeah, silly thing, look for a fix, why spend $125 cdn for a new mirror.
Old 08-25-2005, 08:28 PM
DjEarth DjEarth is offline
I have the same problem. Had to replace the mirror due to it being cracked..part was aftermarket..didn't go through GM as they wanted double over the counter. Now it shakes at fast highway speeds.
Guy that runs a body shop told me there is no way to tighten the glass, but to get some foam..bunch it up and put it in behind the mirror.
Might be a little budget but may just do the trick.
Haven't tried it yet.
Old 08-26-2005, 11:35 AM
Re: Re: Side Mirror Vibration
When your hinge pins were dead, did your door refuse to stay open?
Old 08-28-2005, 12:00 AM
Re: Re: Re: Side Mirror Vibration
Not really. It was just something that they said needed to be replaced , that it was common, and that it needed to be done before the door fell of. Not sure I believed the part about the door falling off. I had the same problem with the mirror, and was going to have it replaced, but when they told me how much it was I was like, fuck that. Then the hing thing came up which kind of had to be done and it fixed it without trying.
Old 08-28-2005, 12:03 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Well somebody recently thought there door was held on by glue and thats why theres fell off supposedly
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 09-09-2005, 07:47 AM
KHFINLAY's Avatar
KHFINLAY KHFINLAY is offline
That is so annoying. Try this hold mirror in place and work switch to tighten it up or move mirror mamually then readjust with switch.Works for me
98 Blazer LT
154,000 miles
Drives like a gem
Approx 18 mpg
Current mods
7 " monitor in passenger headrest, working on drivers
Cassette player replaced with DVD, audio not connected yet
Lots of detailed pics coming soon
Old 09-09-2005, 09:06 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
I had the same issue, I never fixed, I just replaced the mirror. The mirror had a crack so instead of just doing the glass I did the housing and all. Only cost me $50. Well it would have cost that but the glass guy did it for free as long as he got to replace my back window if you catch my drift.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-09-2005, 09:11 AM
Rick1488 Rick1488 is offline
I bought a aftermarket mirror on my truck and it to vibrates... I stuck a foam tape on the adjustable part of the mirror and all is well.
Old 09-09-2005, 03:02 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
You should try and get the newer style mirrors with the large swivel hinge, the older "bubble" style is notorious for cracking on the bottom and vibrating like mad.
Old 10-20-2005, 09:10 AM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
aren't the large swivel hinge kind mirrors only available on 98 and newer blazers?
Old 10-20-2005, 09:13 AM
rlith's Avatar
Yep... Have a set on mine with the defrosters on them.
How to install mirror into LH side mirror assembly? Bill Deville Grand Marquis 2 10-12-2010 11:19 PM
1999 Sebring Conv. right side mirror doesnt move Foxypsycho Sebring | Sebring Coupe | Convertible 0 04-24-2010 06:00 PM
Need Help With Wiring of Side Mirror!!!! civdub21 How-To's and Walk-Through's 0 03-27-2009 08:05 AM
Need Help With Wiring of Side Mirror!!!! civdub21 '96-'00 Civic 0 03-26-2009 11:20 PM
Vibrating Drivers Side Mirror Spinman Aurora 0 05-03-2004 07:50 PM
