Old 03-17-2004, 09:28 AM
speedyvic speedyvic is offline
go to turn engine over.........nothing happens
I have an 85 S-10, I have had it for about 3 years now and it has always done this, it doesnt happen often but sometimes I go to turn it over and there is literally NO noise coming from anywhere, but if I turn it over again then it will start right up. is this a starter problem or an ignition problem?
Old 03-17-2004, 10:30 AM
aleekat aleekat is offline
My parents had a toyota that did the same thing intermittently. The lights, radio etc would work but nothing happen turning the key. They gave the car away to a friend. He found the battery cable was corruded inside the insulation where you couldnt see it without cutting the insulation. Replaced both cables, no problems since. If not cable, then my guess would be the ignition switch.
Old 03-17-2004, 02:18 PM
Re: go to turn engine over.........nothing happens
oh cool, cause my negative battery cable was corruded to the battery a while ago, I did finally get it off but I will look into gettting new cables......thanks
Old 03-17-2004, 08:35 PM
Rostoslav Rostoslav is offline
It could be a bad ground, bad ignition switch, or a bad main relay.
01 turn the key nothing happens rose city Windstar 5 04-26-2009 12:15 PM
turn the key.... nothing happens!!! drew51074 Alero 7 04-29-2008 09:15 PM
Turning engine over without crankshaft damper bolt... (replacing timing belt) Hamon Escort 8 09-27-2005 05:56 PM
91 Escort, starter engages flywheel but doesn't turn engine over. steef Escort 1 07-12-2004 08:26 AM
94 Ford Taurus Wagon will not turn engine over bubbles1977 Taurus | Taurus Wagon 2 02-02-2004 07:53 PM
