Old 03-16-2004, 11:17 PM
1QuIcKsTrEeTcAr 1QuIcKsTrEeTcAr is offline
What would you recomend
I was working with my friend on his project 97 eclipse rs and we're going to be replacing the entire exhaust (headers,catback,muffler) and he wants to buy the apexi n1 catback exhaust but i suggested getting the n1 muffler and 2 1/2" piping going to the cat, it also saves more money. But anyway, do you think the n1 with custom straight through piping will be significantly louder than the original apexi catback because this is something he's worried about. So any help would be appreciated thanks in advance.....also i forgot to mention that he does not plan on putting in a turbo if that makes a difference.
Old 03-17-2004, 01:09 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: What would you recomend
Expensive Apexi 2.5 inch will sound the same as a custom 2.5 inch mandrel. If the muffler is just an 'N1 Style' it won't sound exactly like the brand name one.
Old 03-17-2004, 09:12 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Make sure the custom piping is actually 2.5". Some shops press bend and say it is mandrel bent.
For Sale 98 Eclipse GS, 5 spd
Old 03-17-2004, 09:35 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: What would you recomend
i say 2.25" would be better for a n/a car b/c the exhaust system still needs to retain some back pressure for the motor to run efficently.. it is a n/a car not a turbo motor...
1
Shift_BOOST
97 s14
Old 03-17-2004, 09:40 AM
ashah000's Avatar
I thought you dont want backpressure, you want exhaust gas velocity.
Old 03-17-2004, 09:44 AM
turbo2nr's Avatar
n/a car need some backpressure in the exhaust to maintain their compression ratio..
1
Shift_BOOST
97 s14
Old 03-17-2004, 09:49 AM
kjewer1 kjewer1 is offline
AF - Advisor
False. Backpressure is never good. ashah000 got it right. You want velocity, to exploit the scavenging effect and pull more aif/fuel in during valve overlap. Smaller pipes increase velocity, thats physics. Increased backpressure is a sideeffect of smaller pipes. So unfortunately poeple confuse the two. Its also possible to increase velocity efficiently, meaning less increase in backpressure pre increase in velocity. Thats the whole trick... Ehxuast backpressure has no effect on comrpession ratio.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-17-2004, 10:17 AM
ashah000's Avatar
http://forums.2gnt.com/dcboard.php?a...7337&mode=full
http://forums.2gnt.com/dcboard.php?a...7216&mode=full
Just a few that I found that say that backpressure is bad. I am not really sure on this. Can someone set this straight
Edit >>> Thanks Kevin.
Old 03-17-2004, 12:09 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
im my opinion, the only back pressure you should ever have is durring doggy style.. =)
Old 03-17-2004, 06:04 PM
So basically, getting a custom mandrel bent or just the factory N1 exhaust systems will sound the same? Also what is the diameter size for the factory N1 piping?...Thanks for the replies
Old 03-17-2004, 07:06 PM
ashah000's Avatar
check on google... i think it is 2.5 for the NT exhaust.
Then the one for gst is 3" which will fit on the NT
Old 03-17-2004, 09:18 PM
turbo2nr's Avatar
well i dont noe if back pressure is that bad i got my info from my friend with a 9sec track chevell.. with a big v-8 i dont know the displacement on it all i know is htat the car is fast and he built it him self and races it him self..
1
Shift_BOOST
97 s14
Old 03-17-2004, 11:28 PM
Isn't 3" piping for an NT eclipse pointless considering there's no turbo?
Old 03-17-2004, 11:46 PM
Julioluko Julioluko is offline
yeah buddy you dont need 3.0, go 2.25 or even 2.5, no higher in my opinion.
What would you do with my truck? Any opinions would be awesome. LT1 Kayker C/K 6 01-18-2005 11:37 PM
would you recomend this COBRA 89tracerman Mustang Talk 4 10-24-2004 02:44 PM
Would you recomend? 89tracerman 3000GT/Stealth 10 10-10-2004 02:59 AM
what would you recomend? xlwhellraiser Camaro Discussions 5 08-31-2004 11:27 AM
txr or trx bluebird what do you recomend mc_device Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 2 04-17-2004 05:25 AM
