Old 03-16-2004, 02:32 AM
luvmy99tahoe luvmy99tahoe is offline
Radiator leak
does anybody have a suggestion for batching a small hairlink crack in a radiator that would hold for about 2 months of normal city driving? And I noticed there are two types of radiators for my 1999 Tahoe LT 5.7L. Is the Heavy Duty the better one and does it fit on all 1999 Tahoes? Thanks.
Mike
Old 03-16-2004, 08:55 AM
sprucegoose's Avatar
sprucegoose sprucegoose is offline
I'm assuming that you are talking about the end-cap pieces, which are plastic right? I have read where people use that 2 part epoxy putty over the cracked area as a band-aid fix until the get a new one, or send it down the road. You would want to do this when it is cold, and maybe even drain the fluid down below the level of the crack first. If it isn't seeping when it is cold you may not need to do that.
Make sure you clean and prep the area good first by sanding lightly with 120 grit paper or so, and then clean with acetone or brake cleaning solvent to totally rid the area of any oily residue. One it is pathched give it plenty of time to cure, even overnight before running the system up to temp. It's worth a try!
~Dave~
'08 Chevy HHR SS, Victory Red, 5 spd. 2.0L Turbo, 52K mi.
'98 Buick Riviera, Black, 3.8L Super-Charged, 228K mi.
'98 Chevy Tahoe LT, 5.7 Vortec, Black 241K mi.
'70 Pontiac Firebird Formula 400, 4spd 200k+ mi., in process restoration
'10 Dodge Grand Caravan SE, 11K mi.
Old 03-16-2004, 11:34 PM
that is correct
It is a crack in the plastic. I was told by someone that the entire radiator doesnt need to be replaced. He claimed the same thing happend to him and a radiator shop replaced the plastic side for around $100 insted of $700 for the entire radiator. Has anyone taken this approach?
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 04:02 PM
Oil Leak in radiator Southern Comfort Camaro Discussions 2 07-26-2009 09:40 AM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
Trans Fluid Leaking Into Radiator Coolant Wheels555 Venture 1 03-04-2009 06:18 PM
Radiator leak CBackus2001 Passat 0 11-26-2003 05:19 PM
