Old 03-15-2004, 10:38 PM
srcordray srcordray is offline
Ignition Lock Cylinder replacement
Are any special tools other than a wheel puller required to replace the lock cylinder? How is it secured. Clip? Nut? Bolt? Do I need to watch out for anything jumping up and slapping me in the face then disappearing never to be seen again?? Any assistance would be appreciated.
Thanks
Steve Cordray
Tulsa
Old 03-18-2004, 11:55 AM
Gooseneck Gooseneck is offline
Re: Ignition Lock Cylinder replacement
Been a while since I've been into one, but I remember that you will need torx sockets, don't remember what size. Be careful of the plastic horn wire connector that is spring loaded to the collector ring it is easily broken. The snap ring around the shaft is a little tricky but not to bad. You may need someone to help you compress the slotted lock plate while you remove and install the ring. I THANK? the cylinder has a loaded pin/dowel that you compress to release the cylinder.
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
87 GTI Ignition Lock Cylinder Replacement ewidder GTI 2 07-28-2007 05:03 PM
95 Taurus Ignition Lock Cylinder Replacement HELP PLEASE! hawk06 Taurus | Taurus Wagon 2 06-12-2005 10:42 PM
