Old 03-15-2004, 10:10 PM
Steve Morrison Steve Morrison is offline
Send a message via Yahoo to Steve Morrison
cant find a fuse it likes
We just bought a 91 caravan. Had a few problems but nothing we couldn't fix. And now I've run into a lil stopper. All at once the dash lights and the tail light quit working. Checked the fuses and found one blown so replaced it ad as soon as i turned on the headlights it popped again. I've also tried replacing the relay but it still pops the fuses as soon as you turn on the head lights. Any help anyone could give would be greatly appreciated.
Old 03-16-2004, 09:49 PM
Anaudiophile Anaudiophile is offline
Re: cant find a fuse it likes
Sounds like you're gonna have to find the short to ground somewhere. You'll need a wiring diagram and a test light for a starter. Or, you can take it to a professional to find it for you!
Old 06-20-2004, 12:37 PM
truluv truluv is offline
did you ever fix this ???? Mine did the exact same thing ! Dash lights went out, and noticed my tail lights were out too !! fuse is a 4amp fuse and its not blown. however on testing the socket the fuse goes in, it has no power to the fuse ! anyone have any ideas on where to check for shorts or other fuses im not aware of ?? all other fuses in the fuse box located inside the van are fine. Thanks for any help youcan give.
John
Old 06-22-2004, 09:40 PM
crash8168's Avatar
crash8168 crash8168 is offline
if it has a trailer hitch, start back there first looking for a short.
Old 06-22-2004, 10:31 PM
pegasus757 pegasus757 is offline
"" fuse is a 4amp fuse and its not blown. however on testing the socket the fuse goes in, it has no power to the fuse"" the 4 amp fuse your talking about is for the dash lights and will not be powered untill you turn on the head lights. as far as the first post remove all tail and park (front) lamps ...install fuse ...then one at a time reinstall bulbs
Old 06-25-2004, 01:27 AM
I did test the 4amp fuse socket with the headlights on..it has no power at all... and it doesnt have a trailer hitch. I'm not sure where to look for loss of power to the 4amp fuse. I'm not sure if the parking lights are tied in with the fuse or not ??? it just happened that the dash lights went out the same time the tail lights did. I have headlights and brake lights but no parking lights. Turn signals work also. This problem has got me stumped. just wish i knew where to look ! thanks for your replies...
Old 06-29-2004, 02:26 AM
bump
1971 maverick. cant find fuse box GT-R SkylineX Engineering/ Technical 3 10-14-2008 06:45 AM
NEED HELP! CANT FIND OIL PRESSURE SWITCH AND ECM BATTERY FUSE on my 2001 4.3! hectorm101 Problem Diagnosis 1 03-12-2007 09:12 PM
No Instrument lights in 95GCL-cant find fuse box kenlani Grand Cherokee | Grand Cherokee SRT8 4 12-23-2005 02:52 PM
cant find fuse box nicksastar MR2/MR-S 1 04-05-2004 11:36 AM
Help cant find tail light fuse on 98 Ranger dhofert Ranger | Courier 1 02-01-2004 10:15 AM
