Old 03-12-2007, 07:40 PM
hectorm101 hectorm101 is offline
NEED HELP! CANT FIND OIL PRESSURE SWITCH AND ECM BATTERY FUSE on my 2001 4.3!
while i was drivin the wire that goes to my amplifier came off and shocked my ecm stoping my car instantly and not there is no reading on the fuel gauge.
i have changed the fuel pump and replaced relays and fuses visible. i was told by a mechanic the problem cud b a blown ecm battery fuse but no one knows where it is at,, can anyone please help
Old 03-12-2007, 09:12 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: NEED HELP! CANT FIND OIL PRESSURE SWITCH AND ECM BATTERY FUSE on my 2001 4.3!
Oil pressure gauge sender unit will be on top rear of engine by dist.
There is a gauge and dash panel fuse in cab instrument panel fuse block.
In the under hood fuse and relay block there is a ECM-B and also a ECM-1 fuse
One above fuel pump relay and one on left side of it.
Pull cover off and they should be labeled on under side of cover.
If you have had a short out turn key on and check all fuses for 12 volt power on both side.
Let us know how it goes.
MT
MT
