Old 03-15-2004, 08:46 PM
DirkG DirkG is offline
Angry '84 cherokee wont idle when cold and blows black smoke
My Jeep ran great until I parked it for a while. I had just put a motor in it with 50k on it and a reman carb. Something was causing it to die after it warmed up but would run fine once restarted. I needed to drive something that got more than 15mgp (its a 2.5l) so I parked the jeep and drove it only a handful of times in 3 years. I just moved and when I went to move the jeep it ran great and I had no problems with it. Then a month later I went to go drive it again and it would die whenever I put it into gear. I tracked it down to the break booster. At least that was most of my problem. In the mean time I thought it might be a carb problem. I ended up completly screwing the carb up. Now when its cold the thing blows out tons of black smoke, wont idle at all and barely moves when I try to drive it. I know it is at least running rich, so I turned what I thought was the mixture screw all the way in. That made it a little better. I've also screwed up the idle at warm and cold temps trying to get it to idle when cold. It still wont idle at cold but now it idles at 2500rpm when warm. That makes it VERY hard to come to a stop! What do I need to do to fix this? I called up jeep, they want $200 to look at it. I can chuck the carb and put on a new one for $50 more than that but I dont want to.
Can someone please walk me though what I need to do to tune this carburetor? It cant be as hard as I am making it can it?? There is only one mixture screw and two idle screw that I can see.
Old 03-16-2004, 07:08 PM
Dale Aeppli Dale Aeppli is offline
Re: '84 cherokee wont idle when cold and blows black smoke
SEND ME YOUR EMAIL ADDRESS & I'LL SEND YOU INFORMATION. THE CARB YOU REFER TO IS A THROTTLEBODY IF YOUR ENGINE IS A 2.5--4 CYLINDER. IT SOUNDS LIKE YOU HAVE VACUUM LEAKS. EMAIL DIRECTLY [email protected]
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 03:56 PM
my 90 z 3.1 wont idle when cold 90cavy3.1 Cavalier Problem Diagnosis 1 03-05-2006 12:51 AM
98 F-150 Wont Idle When Cold GITZY F Series 1 12-23-2004 04:27 PM
1990 eclipse rough idle and blowing black smoke agimat788 Eclipse Problem Diagnosis 2 11-08-2004 03:03 PM
1999 silverado wont idle when cold Bubba14 C/K 16 02-04-2004 10:58 AM
