Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 03-15-2004, 07:46 PM
tkrug685 tkrug685 is offline
Question check engine light
i just changed my o2 sensor and my light is still on do i need to reset the computer?
Old 04-05-2004, 02:44 PM
Ahooga Ahooga is offline
Re: check engine light
Yes.... you'll need to have the error code in the ECM reset. Anyone with an OBD-II scanner can do the same for you!
Old 04-05-2004, 11:58 PM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
if you cant locate a scanner, just unhook your negitive battery cable for about 10min, then start it up and allow it to run untill its at operating temp, then drive it normally for a few miles to help the fuel trim adjust, after that it should be fine.
If it aint broke, fix it anyway
Old 04-10-2004, 08:30 PM
onemeantaco onemeantaco is offline
I messed with the cats and the sensor was messed up I was told to pull neg off for 15 min and it would reset the comp
Old 06-01-2004, 06:34 AM
ragdollrider ragdollrider is offline
@ 140,000 miles my check engine light came on, any suggestions?
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
