Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-14-2004, 08:36 PM
ItsDC ItsDC is offline
This is strange --- any ideas?
I completely overhauled the engine in my truck (1988 Ranger 4X4 w/2.9). It runs great, smooth no problems at all, except---.
Here's the catch the tachometer runs backwards (not exactly backwards but more of a reverse, with the engine off the tach rests at full deflection of the gauge "7000 RPM" when started the tach reads about "6000 RPM" as the engine is revved the needle move to the lower numbers "5000 - 4500 RPM" and will not go lower than 4500 RPM). Now, all who have worked on this type of equipment before know that the wiring harness is such that it CANNOT be wired backwards. Now here is another interesting bit of info. I thought that the needle might have flipped due to an electrical spike while reconnecting everything. So, I took the cover off the tach to manually flip the needle back to the correct position. Get this, the truck would not start after that. I put the needle back to the "WRONG" position and the truck started. I repeated the procedure with same results. What I'm thinking now is that I missed or have a bad ground. I think it's trying to find a ground through the tach. What do y'all think? Thanks.
Old 03-21-2004, 09:57 PM
benny27 benny27 is offline
wow
so have you got that fixed yet?
wish i could help but I would not know where to even start
Old 03-31-2004, 09:08 PM
Re: This is strange --- any ideas?
No, still driving it though and messing with things as I think of them as to what might be the problem.
Old 04-01-2004, 12:45 PM
jt-stl jt-stl is offline
Send a message via AIM to jt-stl
Wow, that is wierd
Try posting your problem here http://www.ford-trucks.com/forums/fo...?s=&forumid=35
Old 04-27-2004, 06:18 AM
mitchmerc mitchmerc is offline
Did you reverse the wires on the Tach somehow - just a thought
Strange noises from engine and chassis. Any ideas? Thepeug '88 - '91 Civic | CRX | Wagon | Shuttlee 8 04-26-2005 12:03 PM
Any idea why this car may be so cheap? Mr_Underhill 924/944/968 0 09-19-2002 11:18 AM
Why is this any ideas? ANYBODY?? Sean Price Car Audio 1 05-01-2002 11:24 AM
before i set this thing on fire anybody got any ideas. velocitySiR '71-'87 Civic | CRX 9 04-13-2002 10:51 AM
