Old 03-14-2004, 08:01 PM
travagliante's Avatar
travagliante travagliante is offline
positive door trigger
Im almost finished installing my alarm but i have one more thing to do to make it complete.
In my alarm you need a positive and a negative door trigger. I have the negative door trigger hooked up to the green/red wire on the door. (part where when open turns on dome light, little switch thingy in door jamb.) And i need a positive door trigger and i dont know where to hook it to?
Any help would be greatly appreciated.
Thanks in advanced!!!
Old 03-14-2004, 10:49 PM
n2o_2k's Avatar
n2o_2k n2o_2k is offline
Re: positive door trigger
....In my alarm you need a positive and a negative door trigger ...
I don't think you do.
From what i know it's usually either one .The alarm provides both because there are cars that use positive door trigger (like ford, lincoln and mercury) and others like hondas use negative door trigger. Since your car (i guess) is a honda just leave off the positive , you don't need that (that's what i did when install the alarm on my crx and a friend's accord), the only think you need to hook up is the negative door trigger which you already did.
If you really need both (which i doubt), you can always use a relay.
Hope this help
Old 03-15-2004, 01:43 PM
91EF3ZC's Avatar
91EF3ZC 91EF3ZC is offline
AF Premium User
Send a message via AIM to 91EF3ZC
Yes Like He Said, You Only Need To Use The Negative Trigger Wire. The Positive Is For Vehicles With Positive Door Triggers. You Don't Need It.
Visit my EF page:http://www.pbase.com/luv2hover/91_civic_&page=all
Old 03-15-2004, 06:06 PM
cool thanks, have one other question. Has anyone installed keyless entry with stock power locks, because i need some help. THis is the only part that i cant get installed right. THanks again
Old 03-15-2004, 09:38 PM
n2o_2k's Avatar
Yeah, i did that too. All you gotta do is to connect the keyless entry output for locking and unlocking to the factory lock and unlock wire of your car. What car is for ?
Old 03-16-2004, 11:20 AM
its for a 1990 civic lx. So all i have to do is wire the unlock and lock signal?
Old 03-16-2004, 09:26 PM
n2o_2k's Avatar
Yep that's all you gotta do.
this should be the wiring for your car:
Door Lock Green/White (-)In Driver's Door at Door Lock Module]
Door Unlock Green/Red (-)
so what you gotta now is:
alarm ouput lock --->> Door lock (Green/White)
alarm ouput unlock---->>Door unlock (Green/Red)
Trust me, it's not that difficult. Just gotta make sure that each wire do its function. Also think about having a multimeter, it's helps a lot !!!
Hope this help again.
Door triggers david-b Eclipse Problem Diagnosis 3 09-06-2006 07:15 PM
Door Trigger? chevyguy93 Non-Performance 0 08-04-2005 09:46 PM
94 SE. Where the heck is the front door triggered light switch? BadAz117 Grand AM 6 12-01-2004 10:38 AM
Door trigger sLADe781 3000GT/Stealth 3 08-08-2004 09:17 PM
Alarm installation: Door Trigger Wiring HELP! DocYahoo Car Audio 0 07-17-2002 08:14 PM
