Old 03-14-2004, 04:29 PM
bobfo1 bobfo1 is offline
Program 2004 Pontiac Grand Prix Remote
Is the process for programming a 2004 Grand Prix Keyless Entry remote the same as older models?
Old 04-19-2004, 03:09 PM
Bill DCat Bill DCat is offline
I'm also interested in how to program a remote key fob to work with a 2004 Grand Prix. Thanks in advance.
Old 05-07-2004, 09:57 PM
mike1977 mike1977 is offline
Re: Program 2004 Pontiac Grand Prix Remote
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat.
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
© Copyright General Motors Corporation. All Rights Reserved.
Document ID # 606238
2000 Pontiac Grand Prix
Old 05-08-2004, 12:28 PM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
that procedure does not work with the new grand prixs. it has to be done at the dealer with a scan tool.
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
Old 05-08-2004, 02:34 PM
Avalancher Avalancher is offline
Actually from what I am seeing in my research of it, 2000 and up may need to go to the dealer.
Old 11-30-2004, 07:07 PM
lotsatreez lotsatreez is offline
Angry
so the above mentioned instructions wont work for my 04 grand prix?? (WONDERFUL NEWS) Does anyone know the dealer cost for something like this????
Old 12-07-2004, 04:06 PM
sincere58 sincere58 is offline
It costs around 35 bucks for the dealer to install
Old 12-12-2004, 02:37 PM
aarons04grandprix aarons04grandprix is offline
Do I really have to go to a dealer to get my remote programmed for my 2004 grand prix???
Old 12-12-2004, 11:08 PM
Sorry to say I believe it is the only way, unless somebody knows otherwise
Programming 2001 Pontiac Grand Prix GTX Keyless Entry Remote. feroze Grand Prix 4 05-28-2007 05:32 PM
2004 Pontiac Grand Prix Transmission problem roman1978 Grand Prix 4 03-02-2007 11:29 PM
2004 Pontiac Grand PRix Stereo Removal Zake Grand Prix 2 10-29-2005 09:15 AM
2004 Pontiac Grand Prix civic4g '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-10-2003 09:19 AM
