Old 05-25-2007, 08:34 AM
feroze feroze is offline
Programming 2001 Pontiac Grand Prix GTX Keyless Entry Remote.
Please I need help, I have a 2001 Pontiac Grand Prix GTX and I need to program the second Keyless Entry Remote. It came with one original Keyless Entry Remote and I just purchased another one for my wife. If I program the second remote, I need to know if the first remote (original remote) will work? Can any one explain me in details how to program the second remote. The 2001 Keyless Remote Part Number is 93645564575 and the FCC ID number is L2C0007T. The dealer wants to charge me $50. I have the owner's Manuel and the car was purchased brand new and has only 28,000. Thanks!
Old 05-25-2007, 09:01 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: Programming 2001 Pontiac Grand Prix GTX Keyless Entry Remote.
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock transmitter (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
Remove the ignition key from the ignition lock cylinder.
Close all of the doors.
Remove the MALL PGM fuse from the fuse block.
Insert the ignition key into the ignition lock cylinder.
Turn the ignition to ACC. The body control module (BCM) will perform the following in order to identify the type of BCM installed in the vehicle:
Flash the seat belt indicator 1, 2, or 3 times.
Chime 1, 2, or 3 times.
Turn the ignition to OFF, and then back to ACC within 1 second. The BCM may begin to chime and flash diagnostic trouble codes (DTCs). If the BCM has stored any DTCs, refer to Diagnostic System Check - Body Control System in Body Control System.
Open and then close any vehicle door. The BCM will chime in order to confirm that the programming mode has been entered.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for approximately 14 seconds.
Important
After approximately 7 seconds the BCM will chime once to confirm that synchronization has been completed. After approximately 14 seconds the BCM will chime a second time to confirm that the programming has been completed.
Repeat the previous step in order to program each additional transmitter.
Install the MALL PGM fuse into the fuse block.
Operate the functions of each transmitter in order to verify correct system operation.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 05-27-2007, 07:11 PM
nans_grandprix's Avatar
nans_grandprix nans_grandprix is offline
Important
Important
Will this work for programming another set of keys for a 2002 Grand Prix SE??
Old 05-28-2007, 04:59 PM
Onblsht's Avatar
Authorized Vendor
Same instructions for 01-03
Old 05-28-2007, 05:32 PM
Oh ok thanks very much!!
