Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 03-14-2004, 04:28 PM
newmazdaman newmazdaman is offline
Angry 85 RX-7 no compretion!
Hi i just got a 85 RX-7 i changed the 3 year old gas that was in the tank,
flushed out the old gas in the gas line, and changed the spark plugs, when i turn it over the rpm reads 1000-2000, but if i put some gas down the carb it ends up hitting the 3200 mark, so some one toled me that the read valve might be stuck or chattered, is that the case? can some one tell me Y when i do a compretion test i get 0
tanks for your time and sorry for miss spelling
Old 03-15-2004, 01:26 AM
Aruba27's Avatar
Aruba27 Aruba27 is offline
Send a message via AIM to Aruba27 Send a message via MSN to Aruba27 Send a message via Yahoo to Aruba27
make sure u cover both spark plugs right since there are 2 plugs per rotor, that could do it.
Old 03-17-2004, 09:01 PM
blupajero blupajero is offline
No compression
What is a read valve? Rotaries uses a special compression tester that reads compression on each rotor chamber (3 per rotor). If you use a common compression tester you'll be reading the highest compression, but at least you'll be reading a compression amount. Remove the two lower spark plugs and read the compression. Leave the two uppers in. If that RPM reading is while cranking, the tachometer must be shorted.
efini RX-7 Type-R / Mazda Rx-7 R1 JOSE MARIA Car Modeling 18 03-28-2014 12:59 AM
Mazdaspeed RX-7 GT-C Custom Hiryu Completed Projects / Gallery 5 06-13-2010 11:10 AM
Mazdaspeed RX-7 GT-C “Unicorn” Custom Hiryu WIP - Street 21 06-08-2010 12:31 PM
RX-7 Undercarriage Hiryu Car Modeling 2 10-11-2009 05:15 PM
about mazda enfini rx-7 fd3s n rx-7 sprit r type a... morning RX-7 16 10-17-2005 11:59 PM
