Old 03-14-2004, 12:56 PM
JCP0521 JCP0521 is offline
AIR System
MY SES light came on the other day, I pulled the code that came up AIR System. I check the AIR pump fuses under the battery. The Big 30amp fuse has power in and out but there is no power to the little 10amp fuse, It is not blown though, also no power to the air pump at all, all of this is during idle. On the block with the fuses is a relay, could that be the problem. The SES light does not go off even after disconnecting the battery for 10 Minutes. Checked the power wires with a DC Voltmeter to see if there was any power. Can anyone help?
Old 03-14-2004, 07:16 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: AIR System
you need a scan tool to reset the light. what happens is water gets in the pump and locks it up then the maxi fuse blows. most of the time you need to replace the pump but sometimes you can remove the rubber inlet hoses and dry everything out with compressed air and it'll work again.
good luck
P0410 Secondary Air Injection System shaundavis108 TrailBlazer | Trailblazer EXT 2 03-29-2010 07:36 PM
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
Air Conditioning/Air System Flakey joedali 3 Series 15 12-29-2005 04:18 PM
Wow! On-board air system put to ultimate test warmonger Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 13 06-07-2001 04:51 PM
