Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-14-2004, 12:29 PM
craigie_32571 craigie_32571 is offline
Unhappy 2000 radio odd problem
I have a 2000 jetta GLS, stock premium radio/cassette. I changed out the driver's side headlight and now the radio has no sound (the display reads 88.3 FM - no presets, volume, cassette, etc works but the display lights and alarm system still work. I took it to the local dealer (car!) to get the code for the radio but they didn't put it in because the display did not read "SAFE" (they said I may have fried the receiver putting in the headlight, but wouldn't the fuse have burnt out?) Do you think the radio is just locked? Any help would be Great! Thanks
Old 03-14-2004, 01:54 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: 2000 radio odd problem
Not really. Those Jettas are very bothersome. My dealer blamed me for all my problems because I would put gas in the car!!!!!
Old 03-15-2004, 05:14 AM
Question
I also removed the battery to install the headlight bulb. So, do you think I fried the receiver? Or do I just need the radio code? (since I unhooked the battery) Any help on this would be great.
Old 03-15-2004, 03:31 PM
boschmann boschmann is offline
The radio is able to tell it is still in the same vehicle & doesn't go into safe mode. More likely when you reconnected the battery the power flickered a few times & screwed something up. The only thing you might try is to disconnect the power again & reconnect to see of the problem clears. If problem persists take it to someone knowledgabe with a VAG-COM that isn't wanting to sell a new radio & have them try to re-program the radio.
Old 03-20-2004, 09:19 PM
Thanks Boschmann for the radio tip! You were right on the money!
Intermitent starting problems Driver2001 Grand Marquis 3 10-25-2010 05:56 PM
2000 Accord Rear Window Malfunction pumatiger Accord/TSX/Accord Hybrid 1 08-03-2009 11:56 PM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
Odd problem - no chimes, no radio noelage General Discussions 0 10-26-2008 09:38 PM
galant 2000 radio code problem vicaroo Galant 2 09-12-2008 05:14 PM
