Old 03-14-2004, 12:08 PM
smokeditty smokeditty is offline
Send a message via AIM to smokeditty Send a message via Yahoo to smokeditty
computer help
Ok here's the problem. My 91 crx si doesn't rev past 3 and 1/4 rpm. When I look at my computer the light flashes in sequence of 4 flashes 7 flashes then 9 flashes. I was wondering if my car not reving past 3 and 1/4 rpm has anything to do with the computer. I have a d 15 engine and I'm not sure where the computer came from. Any help would be greatly appreciated.
Old 03-15-2004, 07:33 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
well the flashes are these problems assuming your reading it correctly:
4 Flashes - Crank Angle Sensor
7 Flashes - Throttle Angle
9 Flashes - #1 Cylinder Position
all will have an affect on your rpms, timing, etc.
check to make sure your distributor is on correctly and that the timing is right. also check to make sure you have an SI ecu and not a DX model, same with the distributor.
if that all fails, test the sensor's in each system with a known working model, if they fail there then you know its either an ecu or dizzy problem.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
02 ranger computer help NNY666 Ranger | Courier 2 12-27-2004 11:06 AM
Emergency computer help Steel COMPLETELY off-topic 4 04-01-2004 09:45 AM
computer help...saving images from web sites simdel1 Graphic Manipulation 11 06-22-2003 03:27 AM
Ned computer Help ASAP carmaster COMPLETELY off-topic 6 04-14-2001 02:21 PM
