Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-13-2004, 11:34 PM
3rd 3rd is offline
Angry 1990 overheats
My 90 olds cutless siera get hot and will stop if I slow down. I put it in nuetral and this will help, then it will not start. I have to turn on the heater and that will help sometimes. The radiator always has fluid and so does the resivor. It gets hot but the radiator doesn't come when it happens. I had the fuel pump replaced, fuel filter, fan switch, water pump, fuel injectors cleaned, a tune up and oil change. Please I need any suggestions. It has 93,000.
Old 03-15-2004, 01:35 AM
bargod bargod is offline
Re: 1990 overheats
When's the last time you replaced the thermostat? You say that it stays cool when you are moving, that could be from the air moving around the engine.
Old 03-28-2004, 11:22 PM
3rd 3rd is offline
Re: Re: 1990 overheats
I replaced it last year in sometime in September.
Old 06-24-2004, 11:54 PM
serk16 serk16 is offline
Re: 1990 overheats
Thermostat if not recently replaced, or it is a air bubble which you need to get removed if coolant goes into the reserve tank.
Old 06-27-2004, 07:09 PM
3rd 3rd is offline
Re: 1990 overheats
I have changed the themostat. I noticed that it is happening more and more so I replaced the computer and chip. I really don't want to get another car because I can't afford one. I really don't want to take it to the dealers because I need my body parts
98 Sport Auto Transmission Overheats gromittoo 1st Gen 95-99 1 08-06-2010 06:16 AM
01 Blazer Overheats & Becomes Noisy Smilie1914 Blazer 2 07-11-2010 09:29 AM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 08:16 PM
