Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 03-13-2004, 08:10 PM
Greddy321 Greddy321 is offline
Question Do I need to remove the intake manifold to change Spark Plugs?
Hello everyone, I have been reading this forum for some time now and have learn a lot from you guys. Now I hope you guys can help answer a quick question. I own a 98 Jetta K2 and I want to change the sparkplugs. I notice the #1 and 4 plugs is relatively easy to take out but the #2 and #3 is underneath the intake manifold. Do I need to remove the manifold to remover the two inner plugs or is there a trick to it? Also what should I torque the plugs to when the new ones goes in? Thanks!
Old 03-13-2004, 11:31 PM
danray11 danray11 is offline
HEllo.. It makes it sooo much easier if you remove it. However, It is not mandatory,, have fun
Old 03-14-2004, 12:45 PM
Tacuvito Tacuvito is offline
Re: Do I need to remove the intake manifold to change Spark Plugs?
You will have an easy time, or at least not as troublesome if you remove it. Besides you don't want to mess up the threads when installing the new plugs.
Intake Manifold Gasket End Seals bjaymo3 Grand Prix 5 07-30-2010 08:29 AM
Replace Intake Manifold Gasket Stammtra Cougar 4 07-20-2010 12:13 AM
2002 2.7L Intake manifolds ksparticuspa Intrepid 1 07-02-2010 02:25 AM
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
did i damge the heads while changing spark plugs? mlupone Grand AM 1 02-04-2005 04:43 PM
