Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-12-2004, 09:34 PM
Midusaguy Midusaguy is offline
Knocking Noise/Lifters?
I have a 2wd, 1997 Rodeo that makes a very load clanking noise. I have been told that it is the lifters however, I have done about everything, to fix it... Tried Reso, Heavyweight Oil ect and it still makes the nosie. 80k in milage, it started around 50k Could this be the timing belt. Also I am getting horrible milage around 9 mpg. Not sure if the two issues are related.
Old 03-12-2004, 09:46 PM
rodeo02 rodeo02 is offline
Loud knocking at idle or low RPM's is typically a worn timing belt tensioner assembly on these trucks. This will create enough slack in the timing belt to let it slap against one of the timing belt covers. Many have mistaken this for a rod knock. If you remove your T-belt covers & the noise stops, this is your problem.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-17-2004, 08:17 AM
danforth45's Avatar
danforth45 danforth45 is offline
Re: Knocking Noise/Lifters?
you said you ran heavy weight oil? you need to run a lighter weight like 5w30 mobil1 synthetic. my 97 has a tick and nothing has helped it either. some say lighter weight oils will help because the oil passages are blocked and a thinner oil will penetrate through. Although none of this applies if the t- belt tensioner is worn out. have you changed the t-belt yet?
Old 03-18-2004, 07:12 PM
Cat Fuzz Cat Fuzz is offline
I vote t-belt tensioner. The hydraulic pusher part is what is probably bad and the idler is clanging against it. Cost about $75.00 for the part.
Old 03-18-2004, 08:57 PM
danforth45's Avatar
idler? what do you mean cat fuzz
Old 03-19-2004, 11:26 PM
The idler is the pulley that pushes against the timing belt. The pusher is a little hydraulic piston that pushes on the idler instead of a regular spring like some other cars have.
Old 03-20-2004, 07:49 AM
danforth45's Avatar
so a loose tensioner can sound like a valve tap? is the noise similar to a valve tap, or do they sound different?
Old 03-21-2004, 11:24 PM
Yes. It's pretty loud though. With mine, it wasn't constant though. What happened is the little cylinder got stuck and had stopped pushing on the idler. Eventually the cylinder kept getting pushed back down into the bore and just stayed there instead of springing back out. The idler was banging against the cylinder which was making the noise.
Old 03-22-2004, 09:31 PM
danforth45's Avatar
mine gets louder and quieter, it fluctuates, have you heard anything about this? when you get a new tensioner does it include the hydraulic piston you were talking about?
Noise from Engine Bay jabranko Engineering/ Technical 1 12-16-2010 06:22 PM
Knocking sound, please help!!!! sexione19869 Cavalier Problem Diagnosis 0 06-17-2010 06:49 PM
95 Geo Prizm Rattling/Knocking mattTc17 Nova | Prizm | Spectrum | Sprint 4 03-28-2010 03:31 PM
Rod Knock? NoviceAss Rodeo | Passport | MU 5 11-18-2009 10:55 AM
1996 chrysler cirrus. knocking, but not rod knock or lifter cool_69aa General Discussion 0 09-06-2008 05:24 PM
