Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 03-12-2004, 07:28 PM
Stingwray Stingwray is offline
Question Turns over but can't get spark
I know that this is a fairly open ended question, but here it goes.
I have been working on a 93 Pontiac sunbird for the last 7 months.
One of the major changes was that I swapped the motor about 3 months ago. The previously enjoyed motor that I put in was running before I switched it to my car, and now it turns over and I get no spark.
I have been searching for the problem for the last couple months and have come up with nothing.
Does anybody have an idea on how I can track this problem?
Thank you for your wisdom
Old 03-13-2004, 07:31 PM
neves neves is offline
there are alot of things to check for spark. forst, do all of the cylenders lack spark? check the plugs, wires, coil pack(s), fuses, and all wiring going to the coil(s). if you still have no spark on all plugs, check the camshaft position sensor and the crank case position sensor. these should come up under trouble codes if you take the car to a dealership and get it perfessionally scanned.
Old 03-27-2004, 08:21 PM
Three_Fingers Three_Fingers is offline
Re: Turns over but can't get spark
I have a '93 'Bird and have run into a few problems like this myself.
For one-ya need to check the grounds for the ECM and ignition (if you have the 4 cylinder-it's on the starter side of the block where the negative battery cable goes).
Check your crank position sensor-they're known to crack in half-check to see that the wiring is good to it.
Too wide a plug gap can kill that integrated coil pack on the 2.0L, believe it or not.'
Check the power leads going to the coil(s).
Something could've gotten pinched/broken/shorted during the install.
The scanner will NOT diagnose ignition electrical problems that I know of-it will only see what the ECM sees from it's sensors.
Another thing-if you swapped to the V6 from the 4 cylinder-you hadda change the ECM-make sure all the connectors to it are tight and straight-the PROM chip could be loose or not seated correctly.
Take it out and give it a good slap-if that doesn't make it rattle(meaning the chip fell out and you have to put it back in now), then that may reseat it anough to tell you something (that's how the pros do it).
I have a '93 ragtop 'bird with the 2.0L/auto.
If you went to the 3.1 V6, contact me at [email protected] with '93 'bird in the subject-I got some questions for you.
If you got the 2.0L, talk to me-I've been all through mine and I know it like the back of my hand.
Engine turns over but getting no spark massenm Skylark 2 08-12-2009 03:55 PM
Please help! Engine turns over but no spark! livtyler206 Camry/Camry Hybrid/Vista 7 10-28-2006 03:09 PM
My truck turns over but dosen't produce spark. HELP!!! 73'Camaro Camaro Discussions 0 09-08-2004 08:59 AM
'87 Camry - wont' start, engine turns over but no spark!?! Rouxster Camry/Camry Hybrid/Vista 2 09-03-2004 11:06 AM
95 stang It turns over but no spark jcook249 Mustang Talk 11 07-21-2004 07:09 PM
