Old 07-21-2004, 12:41 AM
jcook249 jcook249 is offline
95 stang It turns over but no spark
I have a 95 stang I was going down the road the other day and the motor just stoped. It's not getting any spark so I changed the coil and still it don't start then I changed the control module and still nothing I checked all the fuses and thay are good. It turns over but no spark. Can anybody help?
Old 07-21-2004, 12:52 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
By control module do you mean the TFI, cause that would be my first guess? How about fuel pump? Is it priming, holding pressure, how much? Did you check for spark at the plugs or the dis.?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 07-21-2004, 01:18 AM
Re: 95 stang It turns over but no spark
control module is the little box under the air intake hose. Is that what you are calling TFI? I checked the spark at the plugs
Old 07-21-2004, 01:24 AM
No I did not check the fuel pump. I did check the reset switch tho it was ok not triped. Do you think by the fuel pump not working would cause it not to get fire?
Old 07-21-2004, 08:21 AM
I'm just getting an idea on whats working, not/working, etc. It just really sounded like TFI to me. I'm not sure where it was located on a 94/95.
Old 07-21-2004, 08:26 AM
Does anybody know where the TFI is located on the 95 stang
Old 07-21-2004, 12:00 PM
Damar Damar is offline
I have a 90 300zx and I just started with the same problems a couple of days ago. I the car just stopped when I checked it out I had a bolt that broke on my timing belt tnesioner pulley so the belt wasnt connected. I put it back together and its still the same thing it turns over and over but will not crank I checked fuel thats fine but no spark. I wish I could help right now but I also have no idea. If I find something out I'll let you know and please let me know if you find something. Good luck.
Old 07-21-2004, 12:02 PM
By the way as far as the TFI I would call the dealership they can tell you exactly where it is.
Old 07-21-2004, 12:25 PM
351wStang's Avatar
351wStang 351wStang is offline
obviously your motor is just way out of time. If your timing belt slipped then you probably have valves opening and closing at the wrong time. Intake valves shut on intake stroke, valves open on compression stroke, ect.
Old 07-21-2004, 12:40 PM
ViprKillr ViprKillr is offline
Re: Re: 95 stang It turns over but no spark
i agree.
Old 07-21-2004, 12:56 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
jcook- the TFI module on 94-95's is under the airbox on a little heat sink. Did you reset the computer after you replaced it? Are you sure it's getting fuel and no spark? sounds like it may be a fuel pump issue to me...
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 07-21-2004, 07:09 PM
351wStang's Avatar
How do you know your not getting any spark? Did you plug in a spark tester or get someone to turn the key after you layed the plug over something metal? Are you sure you are getting fuel? Have you checked for fuel pressure? Should be around 40psi I think, dont hold me to that though. Also how did you check the fuses? Sometimes a blown fuse can look bran new if you didnt test it with a light or meter.
