Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-11-2004, 09:00 PM
hillbilly76642 hillbilly76642 is offline
Send a message via Yahoo to hillbilly76642
Angry truck running bad smells like flooding
I have an 89 4X4 2.9 V6 ranger. My problem started suddenly. When I take off it acts like it's running out of gas but when it's idling it smells like it's flooding and lopes like it has a big cam. I ran the codes on it and got 22,51,53,54. N E help would be appreciated
Old 03-13-2004, 03:04 PM
Andy&Eye Andy&Eye is offline
Re: truck running bad smells like flooding
Hillbilly....Did you tune it up?...I mean everything..I hope thats not a dumb question....I've had the same problem with my 91..
Keep it tuned, and it runs great....
Andy
Old 11-02-2004, 08:42 PM
littledevilbkr23 littledevilbkr23 is offline
Banned
yea Andy&Eye is right, jsut make sure you are up to date with the tuning on your engine, if it lopes it should be the air fuel mixture, just turn the idle screw one full turn and see if it helps, and keep turnign it back and forth till you find the right mixture
Old 11-03-2004, 03:00 PM
Psychopete Psychopete is offline
The idle screw doesn't affect the air fuel mixture. It's to set your idle RPMs. The only successful way I've been able to adjust mine is by converting my computer over to a 1990 MAF Californian Ranger ECU and putting MAF on it with an IST Air Adjuster. Unfortunately your ECU has a built in table that just guesses what the air fuel mixture should be. On a lean or a rich mixture, I've found that my Ranger doesn't have these same symptoms. What you have is a miss. Check your spark plugs. They hold a lot of details on how your engine is actually running. Let me know after you check the plugs, or if you need me to deciper those codes. I do not have my manual handy, and will have to look them up when I get home.
Pete
Old 11-03-2004, 03:07 PM
Just did a 5 second search on google:
22 - MAP Sensor out of range
51 - ECT sensor out of range indicated / circuit open
53 - Fuel injector pump lever sensor input is greater than self test
54 - Intake Air charge temperature sensor circuit open; vane air flow sensor out of range
Something is going awall...
is my truck a flood truck? dearidiot Ram Pickup | Ram SRT10 3 02-04-2013 11:51 AM
95 S-10 won't idle, smells like flooding rknorr Problem Diagnosis 8 12-03-2006 05:06 PM
Bad Smell. Like Vomit BlueFusion6851 Cars in General 9 08-12-2006 09:51 PM
making an intake truck runs bad???? sportin83 Silverado 2 04-01-2005 03:37 PM
truck runs bad at idle 87chev Blazer 0 02-14-2004 08:49 PM
