View Poll Results: ram air VS. cold air
ram air 0 0%
cold air 0 0%
Voters: 0. You may not vote on this poll
Old 03-11-2004, 08:48 PM
travsstuff travsstuff is offline
Send a message via Yahoo to travsstuff
I am 15 and really bored. Should I put in ram air or cold air? Which is better for fast acceleration or whatever?
Old 03-11-2004, 10:14 PM
Nexagen Nexagen is offline
A Ram Air Intake gives you moderate gains about 5 HP+ but a cold air could give you twice as much and that is because colder air burns better than hot air.
Depending on your car and how low your filter is to the ground it will be up to you to decide which one you want. This really also depends on how much space you have in your engine bay. If a cold air intake for your car can go as low as 1 foot close to the ground it is worth it.
Old 03-11-2004, 10:20 PM
Reed Reed is offline
Send a message via AIM to Reed
Re: ram air VS. cold air
a ram air intake will give you the same temperature as a cold air intake if not colder. cold air jsut moves your intake to somewhere further away from your engine ( which makes air around it hot ). A ram air intake takes air from outside of your engine bay and at high speeds helps to compress it. the compression is not noticeable at low speeds and barely noticeable at higher speeds ( nothing like a turbo or sc) but it does help. Ram will give you a little more hp than just a cold air intake.
Old 03-12-2004, 08:45 AM
SaabJohan SaabJohan is offline
What to do depends on the application. However, ram air does only work in higher speeds and give very little gain. It's also very important on where the intake is placed and how it's designed, many intakes I've seen is not only wrong placed but also with the wrong design from my basic knowledge of car aerodynamics.
A simple and very good way is to take in cold air close to the windshield which is a high pressure zone.
short ram intake vs. cold air intake potato957 Grand AM 6 03-05-2008 12:03 PM
Ram air Vs short air Vs cold air wilson4 Engineering/ Technical 13 02-16-2007 04:51 PM
short ram intake vs cold air intake? tipota Engineering/ Technical 7 04-02-2005 02:59 PM
ram air vs. cold air jmrv705 Mustang Talk 2 03-23-2004 09:46 PM
RAM Air VS. Cold Air sidedown Engineering/ Technical 19 02-22-2004 04:26 PM
