Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-11-2004, 06:31 PM
bargod bargod is offline
Changing Spark Plugs
Can anyone explain to me the correct process for changing the rear spark plugs in a 97 Cutlass Supreme withthe 3.1 in it. I tried the braille method and my hands are too big to get behind the engine. Thanks
Old 05-19-2004, 04:02 AM
ludakrissy ludakrissy is offline
Send a message via ICQ to ludakrissy Send a message via AIM to ludakrissy Send a message via Yahoo to ludakrissy
Re: Changing Spark Plugs
youre gonna love this, take the tires off and drop the motor out. in case you didnt notice, our motors are kinda upside down, you either gotta fit in there or take it out.
Old 09-07-2004, 04:37 PM
inconnel209952 inconnel209952 is offline
before dropping the motor out.
Try disconnecting front "dogbone" motor mounts that attach to beam behind rad. Engine will now rotate forward (with prybar) enough to get to rear spark plugs. Same process on my 1990, Just be careful not to damage wiring to O2 sensor when rotating engine forward.
Good luck!
Old 09-08-2004, 05:35 AM
DIY Mechanic DIY Mechanic is offline
I disconnect the torque struts [Dog Bones] and use a ratchet tie down strap to pull the engine forward enough to get clearance.
I also move the couple of items from the top back of the engine for clearance.
I still get scratched up when I remove the plug boots.
Not much clearance by the alternator and no clearance on the other side.
Old 09-11-2004, 07:45 AM
wilfie27 wilfie27 is offline
You can also remove the exhaust mainifold and get to them from the bottom.
Old 09-28-2004, 08:30 AM
tlak tlak is offline
I don't think the configuration has changed since my 91. I had the alternater off and noticed it left a nice hole to change the plugs.
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
Changing Spark Plugs and Wires civickid77 Caravan | Voyager 4 10-23-2004 07:01 PM
changed Spark plugs and i found Oil... shawoo Engineering/ Technical 8 01-22-2004 02:13 PM
Questions about changing spark plugs Kenny4842 Maintenance 2 10-31-2003 02:32 PM
Changing Spark Plug Wires zeff789 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 11-18-2002 04:17 PM
