Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 03-09-2004, 11:14 AM
jtavares jtavares is offline
Daytime Running Light Module
I have a 1993 Jeep Grand Cherokee and I need to unplug/change the daytime running lights module. Does anyone have any idea of the location of it?
Thanks in advance,
Jennifer
Old 04-08-2004, 09:52 PM
ewhite2316 ewhite2316 is offline
I don't know about the 1993 but on the 2004 it is located in the junction box above the fuses. My does not have this module and I am wondering if it is pre-wired for it. The daytime running lights are standard in Canada, but not in the US.
Old 04-09-2004, 03:35 AM
Dsilver Dsilver is offline
Send a message via AIM to Dsilver Send a message via MSN to Dsilver
I would say try what that guy says, or call your local Jeep dealership and ask them otherwise there are books for every make of car that tells you where everything is. They are kinda expensive I think like $30 or so, but if you really need to fix it, it might be worth the cost, plus then you can figure out where anything is, for future reference.
Old 04-09-2004, 07:44 PM
tdenkler tdenkler is offline
Plug location
It's in the "false bottom" of the glove box to the left of "relay center" and to the right of "security access module"
It has a long red connector to it. Just unplug. Should only affect daytime lamps.
the sensor that goes to it is mounted in the top of the radiator support on the pass side. should see small hole with sensor sitting down in hole.
Not sure how to get to it
Old 04-10-2004, 12:59 AM
MrKill MrKill is offline
Re: Daytime Running Light Module
Id like to disable my DRL's on my 2003, might try that out tomorrow if I remember
Old 10-09-2006, 02:26 PM
roel1990 roel1990 is offline
Hello,
Can anyone give me the part number to the Daytime Running Module for a 1993 Jeep Grand Cherokee Limited?
Thanks
Daytime Running Light Module ESSD Caravan | Voyager 3 01-05-2005 01:38 PM
Daytime Running Lights Module jk38 Taurus | Taurus Wagon 1 07-03-2004 06:57 PM
Daytime running light module shnado2003 Caravan | Voyager 3 04-17-2004 07:02 PM
2004 Daytime Running Lights module mike2004tct Caravan | Voyager 0 03-19-2004 05:43 PM
