Old 03-09-2004, 10:18 AM
syk_pal_jgomez syk_pal_jgomez is offline
Send a message via MSN to syk_pal_jgomez
b18C5 swap into a 95-00 civic ex
What are the components that i needs to do the swap into a civic. i just came across a b18c5 for a good price but i needs to no everthing that i am going to need to do or have to do the swap. do any of you know if there is like a website that tells you how to do the swap or maybe a video that shows you how to do a swap. thank you.
Old 03-09-2004, 10:55 AM
steve8091's Avatar
steve8091 steve8091 is offline
Send a message via AIM to steve8091
Re: b18C5 swap into a 95-00 civic ex
You are going to have to clarify whether it is a 5th gen (92-95) or 6th gen (96-00) before anyone can help you.
1998 Honda Civic DX Hatchback
http://members.cardomain.com/steve8091
Old 03-09-2004, 11:04 AM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
It's easy. Use your brain and figure it out yourself. All you need is an engine lift which you can buy for like ~$100. After that, just unbolt the old engine and bolt in the new. Pull out the old ECU, and wire in the new. You will need a 2 1/2" exhaust/catalytic converter though, because your pea-pipe won't fit over the new header and will sound like shit. The only thing a civic engine swap needs is common sense from the installer. If you don't have that, don't attempt it.
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 08:48 PM
Motor/tranny swap 94-95 civic ex civicsavvy JDM Motor & Parts info/chat 3 10-28-2009 03:15 PM
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 12:43 PM
B18C5 swap into a 93 DX......info 93DXon18s Let's get Technical! 0 03-22-2004 01:43 AM
B18c-r swap into 96-98 civic ViperGWSS Engineering/ Technical 1 01-18-2002 02:40 AM
