Old 03-08-2004, 08:24 PM
hardcoreholley hardcoreholley is offline
Question hard jerk when gas pressed
i have a 2002 f-150 lariat.. whenever i start off and push the gas pretty hard it jerks really bad..is that the transmission? i was just wanting to make sure and how that can be fixed?
Old 03-09-2004, 07:51 PM
97chevyman's Avatar
97chevyman 97chevyman is offline
Re: hard jerk when gas pressed
What do you mean jerk? Is there a clunking noise? Does the o/d light flash or anything? Are the shifts hard or are they normal? Are the shift points normal? Does your speedometer read normal speeds?
Old 04-28-2004, 01:44 PM
bigdoggL bigdoggL is offline
Cool Re: hard jerk when gas pressed
I have a 2001 f-150 super crew and it does the same thing, like when i slow down to around 25mph and then mash the gas, feels like it clicks the gear in real hard, and the ford place sd it is considered a hard shift from 2nd to third, and i think tht is nt right. I think tht is a problem. have you found out anything since posting your question
Old 04-28-2004, 03:54 PM
97chevyman's Avatar
does the truck make any noises when shifting from drive to reverse without the brakes on? Coast foreward a little bit and then put it in reverse and then put it in drive again, does it clunk then?
2000 ford F-250 4x4 CC auto
1978 F150 4x4, 6 inch lift painted john deere green
Old 04-28-2004, 04:00 PM
I have not noticed that any, it just kinda makes a hard clunk into the next gear, when i slow down to make a turn onto a road, and then give it gas.seems like it is trying to find the gear or just slipp into it hard. I wil try your suggestion and let you knw if it clunks from reverse to drive.. i think it does just jerks hard whn i do tht.The dealer sd it is the limited slip on the transmission but i hve never had a trnsmission do this.. this is the first ford i have owned.. Just fyi 2001 screw, 5.4 4x4, xlt, with cab shell .. if you have any s
Old 04-30-2004, 02:04 AM
Dougs97 Dougs97 is offline
A friend of mine had this problem. He ended up with a new rebuilt auto-transmission
Old 04-30-2004, 06:54 AM
I have gt a few suggestions and will try these. Thanks for your opinon
Old 05-01-2004, 11:43 PM
97chevyman's Avatar
limited slip is in the rear differential, not in the tranny, some ford shop.
04 impala Shifts Hard when Hot, P1811,shifts hard,jerks chevymandan Impala | Impala SS 3 10-09-2011 04:42 PM
Brakes lock and car jerks when accelerating!! RVanderklerk Taurus | Taurus Wagon 2 02-09-2010 11:00 PM
93' jerks when let off gas!! missy_22 Camry/Camry Hybrid/Vista 1 02-06-2005 03:24 PM
Vibration and jerking when the accelerator/gas pedal is pushed kmeansas Century 1 08-05-2004 11:14 AM
Jerk when I let off the brake or press on it blazzingbrandon 4Runner/GX470 2 08-02-2004 11:17 PM
