Old 03-08-2004, 03:14 PM
GTRhino24's Avatar
GTRhino24 GTRhino24 is offline
Unhappy Door Lock/Unlock Switch Problem
I have a 96 2dr Tahoe LT and since I bought the truck, the interior lock/unlock rocker switches havent worked. Using the remote, the lock/unlock works perfectly. I replaced both driver and passenger side switches hoping that this would fix the problem. Nope, no luck. So knowing that the switches are good, where do I look next? Any common place that I might have a loose wire or bad ground? I dont have a wiring diagram so I dont know where to start.
Ryan
96 Tahoe 2Dr 4x4
315/75/16 BFG ATs (Yes, they will fit.)
2.5" Skyjacker Suspension Lift
2001 Tahoe LT Rims
Old 03-08-2004, 08:04 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Door Lock/Unlock Switch Problem
Well, Power Lock is lt. blue and Power Unlock white and is found in either door boot. The 4 door versions are positive trigger, and the 2 door versions are 5-wire. What that means is if you have a 4dr, those listed wires will show 12v when pressed while the 2dr versions are a little different. They will still show 12v but will also show ground. When one wire is 12v the other is ground. They reverse polarity. Have you tried the switches on the passenger side too? Kinda weird that they work with the keyless and not the switches on the doors
Old 03-10-2004, 09:26 AM
GTRhino24's Avatar
Yeah I have replaced both. I'll get out the fluke later today and test them out. Thanks for the info.
Ryan
96 Tahoe 2Dr 4x4
2001 Tahoe LT Rims
2002 Buick Regal remote control door lock receiver brytheisen Regal 2 07-20-2010 11:07 AM
Door lock, unlock switch on door Malibu 2005 Southlan Malibu 0 01-18-2010 02:52 PM
Door lock switches td57 Malibu 1 07-02-2009 06:26 AM
2003 Grand Prix-Door locks unlock randomly reen910 Grand Prix 1 04-25-2009 07:09 PM
Passenger Door Lock/Unlock Problem mrgrneyyez03 Quest | Presage | Serena 0 05-08-2008 07:49 PM
