Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-08-2004, 01:29 PM
EricinRB EricinRB is offline
Question Wheel straightening or a replacement source
A friend has a 1959 Turner 950 Sports, which came with 15 x 4 inch steel
wheels that have a 4 inch, 4 bolt pattern and a 2 5/8 inch center opening. The wheels were originally made by Rubery-Owen in England, and were also used on very early Lotus Seven Mark 1's. In all the research I've done, I've been unable to determine what, if any, other vehicles that may have used this wheel.
Unfortunately - all four wheels are not straight. They appear to be round, but not 'square'.
Can anyone recommend a good wheel straightening shop in the Los Angeles are?
Does anyone know of another car that has this bolt pattern/wheel center and are 15 inches in diameter?
I do have a picture of the current wheel if that would help.
Thanks
Eric Roberts
Crew Chief, Prancing Basset Vintage Auto Racing
Long Beach, CA
Old 03-08-2004, 03:33 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Re: Wheel straightening or a replacement source
You may want to call someone like Coker tire 1-800-251-6336. They don't stock the wheel but they would likely know who does if anyone still produces them. They deal only with vintage and collector vehicle tires.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Steering Wheel Replacement john3mo Lumina 2 08-25-2010 12:52 PM
How much would replacing/fixing leaking wheel cylinders cost? mrichards28 Lumina 2 06-22-2010 06:09 PM
Air dam replacement source? bruker Rendezvous 1 02-16-2007 12:53 PM
csfi poppet valve retainer replacement source RainRider Tahoe 0 02-18-2006 08:02 PM
