Old 03-08-2004, 10:02 AM
Trailblazer02 Trailblazer02 is offline
Climate Control Fan Settings?
Has anyone had any trouble with the fan settings on the manual climate control unit. the first three setting don't work but 4 and 5 work. This is strange because at first the 5 setting didn't work and one day I got in and 1-3 didn't work but 4 and 5 did. Any suggestions. No problems other than this and my taillight?
Old 03-08-2004, 01:47 PM
tphillab tphillab is offline
I have the 03 Trailblazer, and no climate control problems for me, but I have a friend with a 03 TB and he had the same problem you are having. He took it in and they replaced the switch and problem solved!Hope this helps.
Tod
Old 03-11-2004, 12:20 PM
StefyB StefyB is offline
Unhappy Recurculation shuts off after minutes
I have a problem with my recurculation feature on the a/c unit. It is suppose to stay on until the engine is turned off. Chevy doesn't have a explaination and can't seem to fix it. Anyone else have this problem?
Old 03-19-2004, 09:44 AM
billqual billqual is offline
Re: Climate Control Fan Settings?
The blower motor resistors burn out, they have been redesigned, only cost about $30 dollars and are easy to change.
Old 03-24-2004, 10:10 AM
Re: Re: Climate Control Fan Settings?
Where can I purchase the blower motor resistors and where are they located on the truck? I do a lot of work my self and this is not a problem.
Old 03-24-2004, 11:28 AM
It is a dealer only part, the number is 15415789.
it is located under the right side of the dash at the bottom the the heater case, it is held in by a couple of screws.
I re-read your post, with #5 speed coming & going you should test the switch first, the resistor is solid state and when they burn out they do not usually come back.
Old 05-24-2004, 08:31 PM
billlqual, Thanks for the post. I have fixed the controls.
Old 01-18-2005, 12:29 PM
PJ149 PJ149 is offline
I am having the same problem with my blower controls. 1-3 do not work and 4& 5 do. Did replaceing the switch fix the problem?
Thanks
Old 01-31-2005, 06:50 PM
NewTekBuzz NewTekBuzz is offline
Mine is only 1 & 2 that are out 3,4 & 5 work. what was the fix? the switch or the resistor??
T.I.A.
Old 02-02-2005, 06:37 AM
climate control fan
I am taking it in on Monday (extended warrenty). I am pretty sure that it is the resistor, but that might involve replacing the switch too. I will let you know.
Old 02-21-2005, 05:49 PM
the fix is replacing the resistor, mine was covered my an extended warentee through an outside company.
Unable to adjust climate controls..? ArdiniA Caprice 3 01-06-2010 08:05 PM
AC/Climate Control '02 Silhouette (Venture) andante147 Venture 0 06-24-2009 01:47 PM
climate control fan problems FCOBRAMAN 3 Series 0 01-27-2005 07:28 PM
climate control fan wont shutt off 2000 323 ihavoc Technical 2 12-20-2004 08:51 PM
Calvalier climate control fan switch problem blah629989 Cavalier 4 02-11-2004 03:12 PM
