Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-07-2004, 06:59 PM
martin'steg martin'steg is offline
b18a engine compression
I have a 90 integra and i'm planning on rebuilding the engine, and so i had a compression test done to see just how bad i was sitting. i have the acura shop manual for my car and it says that the stock compression should read 185 PSI in each cylinder and not more than around a 20 PSI variance between cylinders. keeping in mind my engine is 13 years old, i was alarmed to discover that each cylinder read 180 PSI give or take 1 psi. 3 runs on each cylinder were made to ensure accuracy. Each cylinder was also held at this pressure for 10 mins with maybe 1 PSI leakage. I'm not at all complaining about these readings, I'm just very surprised and confused. I don't understand how an engine with 200,000 KM and this old could hold compression like this. It has never been rebuilt or anything. I realize this may be a dumb post, but i'm just tyring to get an understanding of how this may be. I have been told to expect a drop of around 15-20 PSI, but obviously i'm not even close to that. Any suggestions would help me in understanding this.
The engine is the b18a with the standard bolt on mods. I'm working on prepping for a turbo.
Old 03-07-2004, 08:30 PM
unusualcivic's Avatar
unusualcivic unusualcivic is offline
Send a message via AIM to unusualcivic
Re: b18a engine compression
if you've taken good care of it, then its not all that surprising, cause honda engines run forever, compared to most.
84 Civic 1500S
engine- T3 D16a1 with built bottom end in the works
interior- MOMO seats, Sunpro guages, RCI 4-point harness,
sound system- clarion DXZ825, RF Fanatic P's RF 351S, 1 Eclipse SW6123DVC (currently saving for another)
exterior- satin black in progress
Old 03-07-2004, 09:16 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
That is kinda surprising to me b/c of the bad r/s the ls motor has, but if the car has been driven easily and not abused and well maintained then yea that is the payoff
Old 03-08-2004, 10:07 AM
Re: Re: b18a engine compression
please excuse my ignorance, but what is r/s?
Also, on a i-don't-know-how-unrelated note, what would a rediculously large amount of carbon buildup inside the intake manifold suggest? (I'm assuming carbon because i've searched and searched thru threads, and that seems to be what the black buildup in intake manifolds is.) The residue is very black and somewhat slimy (like stale/burnt oil). I'm trying to diagnose what causes this buildup, but i haven't found anything to indicate that. I've only found suggestions of how to clean it out. If it's carbon, where does that come from? if it's oil, does that mean my intake valves may be screwed? Any suggestions would help me understand this. Thanx.
Old 03-08-2004, 04:34 PM
whtteg's Avatar
That is normal you may want to change the PCV valve but the buildup comes from the PCV system.
Also r/s is Rod to Stroke ratio. It is the ratio of the connecting rod vs the amount of stroke the crankshaft has. Basically the lower the number the more side load you have on the cylinder walls and more wear on the piston rings and cylinder walls.
Old 03-08-2004, 05:07 PM
Thanx again whtteg... is there anything you don't know about honda's?
FS: b18a engine and tranny 92teg Classifieds 9 02-04-2005 10:24 AM
Imz-fe engine compression ratio Skyguy Camry/Camry Hybrid/Vista 2 11-03-2003 10:06 PM
Engine Compression Restorer - Does it work? Tanked '88 - '91 Civic | CRX | Wagon | Shuttlee 1 06-05-2003 04:26 PM
Anyone know a distributor of b18a engines? 91civicDXdude '88 - '91 Civic | CRX | Wagon | Shuttlee 2 02-10-2003 03:07 PM
b18a engine .. worth it? sackerius '88 - '91 Civic | CRX | Wagon | Shuttlee 3 08-14-2002 06:57 AM
