Originally Posted by mikeemon
it is all controlled by the turnlever module. you should be able to replace this and it should work right.
My *new* 97 Sable is having a similar prob. with the wipers going at a constant speed (I'm assuming high) reguardless of what intermittent or high/low setting the switch is set at. It's the kind of switch that clicks into position not the smooth adjusting one, and it seems fine on the switch side. :note: The first int. position does nothing (or it's at a really really slow speed) and the rest of the positions are all the same speed. BTW, what is the turnlever module exactly? Is that the actual turn signal switch / multi switch on the steerling column or is this in relation to the little relay that's under the hood that controls the wiper hi/low speeds. I'm assuming since I have no high or low choice it's that module, I have yet to hook my multimeter up to it and test or replace. Should only be a $5-10 part anyway.
Thanks,
Joe
