Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 03-07-2004, 02:29 PM
jmslms jmslms is offline
Radiator fan only comes on if I turn on the A/C or Heat!!?!?!
I have had the same problem with both of my Jettas (86 and 88). They both have sat for over a year at one time before I bought them.
The radiator fan will only come on if I turn the A/C on or the defroster.
I have tried to figure out what the problem can be, I had replaced the temp switch on the radiator and the relay switch on the 86, but it still didn't fix the problem.
I just got my 88 carat and it is doing the same thing, but I wanted to see if anyone else has had the same problem and if they figured out how to fix it?? any help is greatly appriciated!!!
Thanks
Old 03-08-2004, 05:13 PM
boschmann boschmann is offline
Re: Radiator fan only comes on if I turn on the A/C or Heat!!?!?!
You should have a red/black, red/white & brown wire at the fan motor. Try connecting a jumper wire from battery positive to the red/white wire terminal on the fan motor (brown wire terminal will have to be grounded). Fan should run on low. If you connect it to the red/black terminal it should run on high. If the fan works, the problem is often with the fan connector itself.
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
Radiator Fan not turning tnoyes30 Cherokee 1 03-16-2010 03:44 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Overheating, radiator fans do not turn on:where is the relay? Vickers Caravan | Voyager 5 06-16-2004 06:03 PM
radiator fan not coming on jluhrsen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 10-09-2003 09:05 PM
