Old 03-07-2004, 03:26 PM
Markgase2000's Avatar
Markgase2000 Markgase2000 is offline
Send a message via Yahoo to Markgase2000
Cams for lower compression?
Are there any proven cams for 3400 sfi v6 (2000 ga) that will lower the compression so i could use a turbo?
Old 03-10-2004, 01:36 AM
Re: Cams for lower compression?
none?
Old 03-10-2004, 11:25 AM
shark2000's Avatar
shark2000 shark2000 is offline
Send a message via ICQ to shark2000 Send a message via MSN to shark2000
As fare as I know, you need a head gasket set that can lower your compression. I've never dealt with it before, but as a vehicle mechanic, I would think it is thicker so the combution chamber is slightly larger to give more room for lower compression. That's just my guess, as I've never done stuff like that. Just from reading magazines about performance.
My Grand Am Picture Site
_____________________________________________
2002 Grand Am GT
77 Dodge Power Wagon
2006 Charger SXT 3.5L V-6
2011 Charger RT 5.7L Hemi
2008 CLK350 Convertible
Old 03-10-2004, 06:28 PM
urweak urweak is offline
Banned
Send a message via AIM to urweak
yea, cams arent going to give you lower comprestion ratios, you have to get a thicker headgasket, or lower comprestion pistons, or both.
Old 03-10-2004, 11:31 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Fel-Pro makes Some thicker Gaskets I think .080 is the thickest you want to go? Might be to thick if you plan to use a Turbo? What is the Comp Ratio for that engine anyway? 9:1 or something like that?
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 03-10-2004, 11:36 PM
10:1 i believe
Old 03-10-2004, 11:37 PM
so all i needed was a stupid gasket , crap..
Old 03-10-2004, 11:45 PM
That seems kinda high? lemme check on that.
Why what did you get?
Old 03-11-2004, 12:05 AM
sure
Lowering Compression Ratio QuakeWork120 Forced Induction 8 04-20-2004 11:05 PM
Larger Head gasket=lower compression= Safer boost? Hellraiserrob Forced Induction 22 03-03-2004 01:18 AM
lower compression ratio Crippy Engineering/ Technical 2 01-30-2004 10:07 AM
KA24DE lower compression pistons KATRick 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 11-10-2003 10:11 PM
how to lower compression ratio? liquid8 Forced Induction 5 03-11-2002 05:59 PM
